nuetral issues
Posted: Sun Jan 17, 2010 7:40 pm
by dunebuggyq
I have a 1991 FZR 600 that has issues with going into nuetral. It usually just skips by it and goes into first or second. Everything else gear wise shifts great so i am at a loss of thoughts. Thank you for any help banghead
Re: nuetral issues
Posted: Mon Jan 18, 2010 8:16 am
by dunebuggyq
oil level is good and clutch adjustment seems fine it catches about half way out
Re: nuetral issues
Posted: Mon Jan 18, 2010 1:06 pm
by kilika2
I did a wiki search and there was a guy that was having the same problem, I don't have the link now cause I'm at work and I found it on the home computer. But as I recall it was basically everything that 95 told you too.
Re: nuetral issues
Posted: Mon Jan 18, 2010 8:11 pm
by dunebuggyq
If you coud send me the link i would greatly appreciate it.
Re: nuetral issues
Posted: Mon Jan 18, 2010 10:46 pm
by kilika2
I'll try to copy the link, I'm using my ps3 and the copy/paste is weird. If it doesn't work search gear selection problem at the top of this screen and it will bring it right up.
viewtopic.php?f=7&t=3712&start=0&hilit=neutral+problems
There we go. Scroll down a bit the later stuff is more for you. At the beginning the guy is having the opposite problem. Hope this helps.
Chris
Re: nuetral issues
Posted: Tue Jan 19, 2010 9:17 pm
by dunebuggyq
thanks for all the help
Re: nuetral issues
Posted: Tue Mar 16, 2010 8:26 pm
by dunebuggyq
Just an update guys it was the detent lever that was broken causing my problems just replaced it with one from Factory Pro works great now. RRBike
