Page 1 of 3
transmission whine... normal for these bikes?
Posted: Tue Jun 10, 2008 5:13 pm
by kingcobra
as it says... I have a bit of transmission whine and just makin sure it's normal. no weirdness... shifts fine and everything just speed matching whining...
Re: transmission whine... normal for these bikes?
Posted: Tue Jun 10, 2008 5:57 pm
by ThisEndUp
Are you sure it's not the cam chains that you're hearing?
I've never heard an FZR transmission whine.
Posted: Tue Jun 10, 2008 6:04 pm
by kingcobra
well no I'm not sure... how would I know the difference?
by haunter
or intake whine
Posted: Tue Jun 10, 2008 6:05 pm
by kingcobra
just thinking... the whine doesn't vary with engine rpm... it varies with bike speed. so I don't think it's cam chains.
Posted: Tue Jun 10, 2008 6:06 pm
by haunter
hmmmm I dunno
Posted: Tue Jun 10, 2008 6:32 pm
by ThisEndUp
What condition are your chain and sprockets in?
Is the chain properly tensioned?
Posted: Tue Jun 10, 2008 6:34 pm
by ThisEndUp
Can you put the bike up on a rear stand and spin the wheel?
Could also be your rear wheel bearing going south.
Posted: Tue Jun 10, 2008 7:27 pm
by kingcobra
chain and sprockets are all new and tension is correct... I'll check the wheel bearings next
Posted: Tue Jun 10, 2008 7:31 pm
by haunter
wheel bearings are cheap(even the good ones from all balls) and pretty easy to swap out so lets hope thats it!
Posted: Tue Jun 10, 2008 10:12 pm
by PIMPMYFZR
hm not to jack this thread , but with the wheel on the stand is it supposed to turn freely kinda like a bicycle , because mine doesnt complete a full turn ..? and i have that whining sound also
Posted: Wed Jun 11, 2008 2:28 am
by smoktt2020
Mine has a louder 2nd gear and 6th gear whine then any of the other gears ..... well it looks like a little extra wear on those 2 gears .... After i installed a new DID chain and new sprockets , the whine was not near as bad , but it was still there ... The guy across town put a new non-sealed drive chain on his bike and said it made it whine louder then before .... Tranny design wear & tear , worn drive chain and sprockets , it's gonna whine up a storm .
Posted: Wed Jun 11, 2008 2:42 pm
Ok this will sound strange. I had a similar whine on my Z750 the was really apparent above 5000rpm. I adjusted the chain and changed the oil...no more whine.
Posted: Wed Jun 11, 2008 8:49 pm
by shooshine_jonnie
thats how I know that I'm in second gear. It whines and its pretty loud. But thats the only gear it whines.
Posted: Wed Jun 11, 2008 9:00 pm
by modkingfzr600
get some loud exhaust , that whine will go away instantly. LOL anything with a gearbox is gonna whine so i would get used to it, you may try some full synthetic oil to quiet it down a little .
