So, It tried and tried but wouldn't fire. No popping or sputters nothing just cranking like crazy. I checked to make sure I had gas in it and didn't just get lucky on getting back home but has gas in the tank. i decided to then take my car to work. i got home later that night and after trying quite a few times in the morning the battery started to get drained. so i jumped it from my car to the bike since i don't have a batt. charger or a jump box.
it started and idled for maybe 45 seconds and i tried revving it and it bogged down and out and never has started again. i checked all fuses and I did a compression test and all are within spec 160+. Then I changed plugs and removed autolites which I thought may of been the problem but nope..so I put in the NGK plugs it needed made sure gap was right.
Nothing is in the airbox, I checked that right away
what I should do as my next step so if someone would like to recommend what I should do next that would be a huge help. To take carbs off seems like a pain in the ass so im wondering if there is anything else i should check first. Thanks a lot.
