Dead! Bike quit, no power!!
TomGun
Level 2.5
Level 2.5
Post by TomGun »
SO I was just getting ready to go home for lunch, slipped the helmet on started the bike put up the kick stand, put it into gear, then puff!! no power! no lights no nothing. :swear Multi meter says over 12 Vdc on the battery. Fried the voltage regulator perhaps?? It was sitting in the sun all morning, and its hot here today, 95+.. Anyone have any ideas??
Looking for a FZR 400 3TJ
1992 FZR 600 SOLD :-(
2001 Ducati ST4 916
The Yellow Duc Project
megaloxana
Re: Dead! Bike quit, no power!!
Post by megaloxana »
Did you check all the fuses?
TomGun
Level 2.5
Level 2.5
Post by TomGun »
All fuses checked, and there all good! still no power!
2001 Ducati ST4 916
tommyj27
Level 9.5
Level 9.5
Post by tommyj27 »
Dumb question, did you check the ignition fuse located near the VR?
ragedigital
4000+ Posts
4000+ Posts
Post by ragedigital »
Kickstand switch - perhaps?
haunter
Post by haunter »
ragedigital wrote:Kickstand switch - perhaps?
x2
TomGun
Level 2.5
Level 2.5
Post by TomGun »
The fuse to the VR was fried! had a spare 20 Amp put it in and presto! bike fired up for now.. Now why did the 25 Amp fry in the first place? broken ground somewhere? So I'll ride home for lunch and "see what happens" RRBike
Thanks for the help guys!
tommyj27 gets the prize!
2001 Ducati ST4 916
TomGun wrote:The fuse to the VR was fried! had a spare 20 Amp put it in and presto! bike fired up for now.. Now why did the 25 Amp fry in the first place? broken ground somewhere? So I'll ride home for lunch and "see what happens" RRBike
I would check the voltage to the battery with the engine running at idle then rev it some, my guess is that it will go high and that the VR is overheating in the +95 and running temp
Hope I am wrong
sweekster
Post by sweekster »
Agreed I'll also bet you still have the stock VR? I'd say do the upgrade. I recently did it to my FZR because when i made an effort to actually check the voltage going to the battery i was getting almost 30 volts.
TomGun
Level 2.5
Level 2.5
Post by TomGun »
So I did make it a couple of miles down the road. Then it popped again. Stranded, hot and pissed off, I decided to disconnect the headlight (just for kicks), and borrow the fan fuse (10Amp) and see if I could make it to Autozone and grab a few fuses to get me home. From there to Autozone no problem. Replaced the fuses. (put some spares in the fuse box) and made it home with no issue. SO I'm inclined to think that is the VR overheating, as suggested. So I parked the bike in the shade, and this evening I'm going to plug the Headlight back in and go for a short ride "and see what happens". Meanwhile I'm going to look up the threads on VR replacement. Seems like the OEM VR on the Fizzer is a weak point from what I've read. :thumbsup:
2001 Ducati ST4 916
tommyj27
Level 9.5
Level 9.5
Post by tommyj27 »
It's pretty easy to diagnose: viewtopic.php?f=8&t=157
R3TARD
Level 4.5
Level 4.5
Post by R3TARD »
Be careful your playing with fire pushing a hot VR. You could easily fry your cdi even with the inline fuse in place. It just happened to me.
1992 FZR 600
Yoshi exhaust
K&N pods
Airtech R1-kit
02 R6 fork swap
02 R6 Swingarm
520 chain conversion
07 R6 controls
Vortex R6 clipons
07 R6 radial master
2003 CBR 600rr
bone stock
haunter
Post by haunter »
TomGun wrote:Seems like the OEM VR on the Fizzer is a weak point from what I've read. :thumbsup:
so far this is the biggest understatement posted on this board :whistle
:shocker
Modified96
Post by Modified96 »
Mine was doing that when I first had it. It left me stranded with burned fuses, lights, wires...ect. I would say DON'T ride it until swap that VR, or do a thorough test on it. A burned VR can make a huge mess.
"There he goes. One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die." - Fear and Loathing
tommyj27
Level 9.5
Level 9.5
Post by tommyj27 »
haunter wrote:so far this is the biggest understatement posted on this board :whistle
:shocker
LOL2
