Two Quick Questions: Fuel Tank and Cylinder Order
I pulled off the tank this morning and upon looking in I see the a little tube, about an inch long, sticking out of one of two holes at the bottom of the tank. Ok, that's the Fuel On tube, and the open hole is the Fuel Reserve mode.
But then I see a 4 inch section of the same type of tube rolling around the bottom of the tank.
My old dirt bikes all had about one inch tubes splitting the On from Reserve, so this four inch piece seems rather long.
Any body know what's up?
Second, and simple one: I checked the plugs and need a quick confirmation on cylinder order. It just goes 1-2-3-4, left to right when sitting on the bike, right?
Thanks!
Thanks!
1998 FZR600
30,000+ odo
30,000+ odo
Re: Two Quick Questions: Fuel Tank and Cylinder Order
I meant the plug order, not firing order, if that is what you are referring to.95FZR600 wrote:1and3 2and4
one goes to fuel pump other to tank
What do you mean one to the fuel pump and one to the tank?
1998 FZR600
30,000+ odo
30,000+ odo
WSM wrote:Second, and simple one: I checked the plugs and need a quick confirmation on cylinder order. It just goes 1-2-3-4, left to right when sitting on the bike, right?
No. It goes 1,3,4,2. (#1 TDC@ 0°, #3 180°ATDC, #4 @ 360°ATDC, #2 @ 540°ATDC and then #1 again at 720°ATDC/0°TDC)
One coil fires #1 and 4....the other fires 2 and 3.
there should be a screened tube for both on and reserve i never really looked at them ive seen them in dirtbikes and other things but never needed to get into the fzr tanks but there is a screen for both and ones longer than the other for obvious reasons so the otherone rolling around gos into the petcock and i belive its 1 threw 4 left to right like you said coils are 1 and 4 on first and 2 and 3 on second coil
haro504 wrote:nd i belive its 1 threw 4 left to right like you said
WSM wrote:It just goes 1-2-3-4, left to right when sitting on the bike, right?
no.
#1 and #4 are on the same plane as each other (both are up top at the same time) AND #2 and #3 are on the same plane as each other 180° different than 1 and 4 (both are at bottom when 1& 4 are up top).
The firing order CANNOT be 1,2,3,4 in sequence.
not the fireing order the cylinder number order i know they dont fire in a rowhe was asking for the numbers to i dentify the cylinders
Thanks haro.haro504 wrote:not the fireing order the cylinder number order
1998 FZR600
30,000+ odo
30,000+ odo
haro504 wrote:not the fireing order the cylinder number order i know they dont fire in a rowhe was asking for the numbers to i dentify the cylinders
Ahh, jeez. I was overthinking it. sry.
Yeah, the japanese count everything (motorcylel engine-wise) in order from the flywheel-even on V-4s and V-twins, and flat sixes
Good to know. Thanks.reelrazor wrote:Yeah, the japanese count everything (motorcylel engine-wise) in order from the flywheel-even on V-4s and V-twins, and flat sixes
1998 FZR600
30,000+ odo
30,000+ odo
- kilika2
- 1000+ Posts
Yeah I was getting worried when reading this cause my plug boots had numbers on them and I put them in cronological order. Got scared that I did something horrible.
Chris
Chris
1995 FZR600 Sold
2006 R1 Sold :-\
2009 Buell 1125R
- fzrbrandon
- Level 7.5
Did anyone catch this or did I read through the thread too fast? LOL! This should be the "ON" pipe correct? And if it's "rolling" around the bottom of the tank it needs to get fixed (new petcock maybe?).WSM wrote:But then I see a 4 inch section of the same type of tube rolling around the bottom of the tank...
http://www.fzrbrandon.com
Yeah, that's what I am figuring. Next time one of you guys are on empty, get a flashlight (not a lighter!) and check your tank.fzrbrandon wrote:Did anyone catch this or did I read through the thread too fast? LOL! This should be the "ON" pipe correct? And if it's "rolling" around the bottom of the tank it needs to get fixed (new petcock maybe?).
Let me know.
You think I could just remove the petcock from the bottom and shove the tube back in? Glue it?
1998 FZR600
30,000+ odo
30,000+ odo
They just pull out. At least the few I've messed with do. It's not a real good pressure fit. The longer tube is for regular tank operation and the shorter one is for reserve. They both go into the petcock.WSM wrote:Yeah, that's what I am figuring. Next time one of you guys are on empty, get a flashlight (not a lighter!) and check your tank.fzrbrandon wrote:Did anyone catch this or did I read through the thread too fast? LOL! This should be the "ON" pipe correct? And if it's "rolling" around the bottom of the tank it needs to get fixed (new petcock maybe?).
Let me know.
Next time your tank is empty just unscrew the petcock and shove it back in there.
