Help with the carbs. the screws from the floats are stuck
trifgeorge
Post by trifgeorge »
I've just pulled the carbs off the bike so i can clean them. The big problem is that I'm stuck at the screws that hold the floats covers in place. They are stuck and I cannot unscrew them. They are like butter and wear down very fast and I used a high impact screwdriver from the beggining.
Anyone has any idea of how to unscrew them?
1992 Yamaha FZR 600 3HE with:
Sigma BC 1009 speedometer
YZF 600 Thundercat tank
Red Rizoma like grips
R6 pilot seat
R6 Voltage regulator
Custom made rearset hangers
KOSO mirrors
FZR1000 hydraulic clutch
H1 HID
Hand made mirror plates
reelrazor
Wrench
Wrench
Re: Help with the carbs. the screws from the floats are stuck
Post by reelrazor »
small vise-grips. You should only need to turn them an 1/8 turn with the grips.
Then hop on down to your local hardware store and get Allen screw replacements.
cad600
Post by cad600 »
Liquid wrench, a Dremel to cut a straight blade notch in the screw, and a hand held impact driver using a large straight blade. Works every time, just don't hit the carb body with the hammer.
sh0rty77
Post by sh0rty77 »
You can use a hacksaw and cut a slot in the top of the screw and use a flat head screw driver if the screw is rounded.
FZR600 10/90
Single Headlight
Single seat
Working progress
reelrazor wrote:small vise-grips. You should only need to turn them an 1/8 turn with the grips.
If you have chewed the heads RR is right vice grips will finish them off completely. However just before you use the vice grips, just tap the screw heads with the flat face of a hammer (be sure to support the carb lug the screw goes into UNLESS you wish to snap off the carb lug :-}
By hammering the head you do two things:-
1} Reform the crew slots just enough for a screw driver to gain purchase of not some air wrench type driver
2} break the corrosion that is holding the screw so tight.
In any other situation BUT carbs I would use heat to break the corrosion.
As ReelRazor said go get your self some 4 mm allen screws & use anti seize on the threads BEFORE installing them
trifgeorge
I got it sorted out. I drilled the screws and i'm getting new Allen screw replacements. One more question. Which are the factory settings for the carbs?
R6 pilot seat
KOSO mirrors
H1 HID
