just like the title says
im wondering what voltage regulators i should be lookin for(what years mainly)
i have a couple saved sites on the swap itself,,but i dont believe they list a year
i think i can swap over a 1996 FZR 600 and up regulator???
and the R6,,and YZF
i just wanted to know what specific years i should be lookin for
thanks
what voltage regulators to replace my 1989 FZR600 unit
- shredex
Re: what voltage regulators to replace my 1989 FZR600 unit
any year YZF, and any year R6.
Im sure the R1 works to.
As above BUT you will need to modify the bikes loom as the old VR has 5 pins the new ones have six.shredex wrote:any year YZF, and any year R6.
see:::;-
http://www.saltmine.org.uk/fzr/vr.html
for one way to do this.
You will need to modify the wire harness anyways. The '89 model used a 4 pin VR. The '94+ uses a 5 pin that allows you to plug the newer one right in. I would modify your wire harness and use the newer VR's as they are much better. Check out the Wiki or do a search to find out how. It is really easy.
89fzr600rr
this is as easy as he makes it sound ... just remember to wear eye protection when your grinding ... metal shards dont tickle when they get into your eye
also on that note if it does happen go to your eye doctor within 2 hours so he doesnt have to scrape the rust off your eye .. cause that shit doesnt tickle either
