what kind of header is this?
match417
Level 8.0
Level 8.0
Post by match417 »
This is a 96 bike, but the header looks completely different than the header that was on my 91 FZR.
haro504
Level 7.5
Level 7.5
Re: what kind of header is this?
Post by haro504 »
from the pics you took it looks like the fzr header thats on mine
match417
Level 8.0
Level 8.0
Post by match417 »
95FZR600 wrote:Cant really tell from the pics. Is it 4-2-1?
no, it's 4 into 1, are all the FZR600 headers the same through all the years? I'll take a better picture of it when I take the side fairings off.
sweekster
Post by sweekster »
That's a stock 49 state 600 header. As far as I know they were the same for all years but I'm not too sure about the 89 as there are some small differences between that bike and the later models.
the_finch
Level 8.5
Level 8.5
Post by the_finch »
sweekster wrote:That's a stock 49 state 600 header. As far as I know they were the same for all years but I'm not too sure about the 89 as there are some small differences between that bike and the later models.
+1
1997 FZR600RJ
match417
Level 8.0
Level 8.0
Post by match417 »
This is the header on the 96 FZR compared to the header that was on my 91 FZR, also I took the side fairing off so you guys can see it better. One of the headers isn't stock, unless there are two different stock types. Hope you guys can see the difference, it (96 FZR one) really sticks out toward the front tire a lot..it doesn't look stock. I think the header that was on my 89 FZR looked exactly like my 91 header.
shredex
Post by shredex »
they loo like the ugly stockers to me
sweekster
Post by sweekster »
match417 wrote:Image
The one in your hand=Not Stock (notice it's a bigger diameter?). Probably a V&H (I could be wrong though)
The one on the bike=See my previous post
FasterThanUr
100+ Posts
100+ Posts
Post by FasterThanUr »
kinda looks like the muzzy I use to have on mine.
90 FZR400/98 Fzr600 engine
Tom Tom GPS
05 R1 passanger pegs
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
I hooked my brake light switch to my throttle,so when I hit the gas everyone would slowdown and I would be gone :headbang:
match417
Level 8.0
Level 8.0
Post by match417 »
oh, wow, I guess it was a Muzzy I had on mine, it looks exactly like yours, except mine was a lot older, I had an exhaust leak though, right between where the pipes merged into one. I wondered why it was the same size as the R6 header that I got that I was going to put on, people said the R6 header was a little larger (in runner diameter) than the stock and I thought I had a stock one but it was the same size so I was confused, now it makes sense. Oh well, I have a stock YZF600 header on now, and it's the same size as the muzzy but it's 4-2-1 instead of 4 - 1. Good to know..thanks! Now I might even consider welding a patch in the Muzzy header and sanding it and painting it with high temp paint so it looks better. Crap, but it won't fit with the YZF600 oil cooler that I have on now.. :ermm: ..crap ..sorry, I'm rambling/thinking..lol
