Knocking at low rpm
olie05
Knocking at low rpm
Post by olie05 »
I just noticed my bike is doing this:
From a dead stop, warmed up or not, if I let the clutch out slowly and give throttle, from about 1300 rpm to 1600rpm I will hear a quiet knocking sound as I accelerate. I have tried replicating the sound by holding the brake and throttle at around those rpm with varying degrees of load, but it seems to happen the most when i'm just accelerating from a dead stop. It sounds like it might be coming from the left side of the engine.
Also, the sound does not happen at any other RPM range.
I know i need to lube the chain,
I know I need to change oil.
besides these things will there be another source for this knocking sound?
Should I pull the pan and check the rods?
I need some advice on this issue!
reelrazor
Wrench
Wrench
Re: Knocking at low rpm
Post by reelrazor »
Is it only when moving (rolling)? Seem like it is tied to the wheelspeed? Suspect your chain/sprocket setup. All it takes is one 'hooked' front sprocket tooth, or one kinked chain link to make a sound like this.
olie05
Post by olie05 »
Do i just check for this with the rear wheel up or is it any more involved?
I was eying the 520 chain conversion anyway, so this could be good.
mossy1200
Level 5.0
Level 5.0
Post by mossy1200 »
I take off at 7000rpm so cant help you there.
olie05
Post by olie05 »
I took out some of the slack in the chain, lubed it, and the noise seems to have stopped. Could it have been the chain slapping against the swingarm somehow?
