idling around 3k
stan
idling around 3k
Post by stan »
'92 here, and ive got an idle problem screwy . the bike runs great in all respects :banana: (just bought recently) but it idles around 3k! i havent cracked into it yet but where should i start? hopefully this isnt a :duh: question
help me guys!
:udaman
syvmn
Re: idling around 3k
Post by syvmn »
Look on the left side of the bike (I think). There is a screw for adjusting the rev. It has a cable attached to it that runs back into the engine somewhere.
mrfreeze5
Level 8.0
Level 8.0
Post by mrfreeze5 »
Start with the idle screw. If that doesnt really fix the issue, you may have a vacuum leak. Check the rubber boots the carbs attach to and make sure thay are not cracked or dry rotted anywhere. Also make sure the carbs are fully seated on them.
mrfreeze5 wrote:Start with the idle screw. If that doesnt really fix the issue, you may have a vacuum leak. Check the rubber boots the carbs attach to and make sure thay are not cracked or dry rotted anywhere. Also make sure the carbs are fully seated on them.
Mine will idle at 3k with the "choke" on just make sure that cable has not jammed open as mine had when it first arrived. after standing 2 months after it fall.
