does the fzr600 have a tag light??
or am I going to have to wire up my own tag light system on the bike?
I guess I can wire it threw the with the guage lights...
fzr600 Tag light?
Re: fzr600 Tag light?
mines in my brake light not for long tho
The bottom of the stock tail light is clear so light shines down on the plate. I suggest adding a relay if add the light otherwise you'll pop fuses.
- shredex
what if I wire it into my guages and go up one size fuse on guage fuse?sweekster wrote:The bottom of the stock tail light is clear so light shines down on the plate. I suggest adding a relay if add the light otherwise you'll pop fuses.
I just added an LED to the daylight wire of the rear tailight - should be blue. Add the appropriate resistor.
You can see it in this image - it is a small led inside of a chrome led holder:
Wire it into the blue running light wire like it should be. A led doesnt draw much, so try it with just the LED first. If you pop the fuse, add a relay. Dont make it more complicated than it needs to be.shredex wrote:what if I wire it into my guages and go up one size fuse on guage fuse?sweekster wrote:The bottom of the stock tail light is clear so light shines down on the plate. I suggest adding a relay if add the light otherwise you'll pop fuses.
