Chain adjusters
Posted: Fri Aug 14, 2009 4:07 pm
by delvryboy
Has anyone had these lock up on them? I can't get them to budge, the double nuts back right off. Wouldn't be a problem if I was trying to add slack to the chain, but unfortunately I'm trying to tighten it. PIMA.
Re: Chain adjusters
Posted: Fri Aug 14, 2009 4:39 pm
by delvryboy
Ok, this thread actually helped. It got me out of the 90+ degree heat, sat in the AC, drank a half gallon of water, and had a smoke. Went back out and 15 minutes later, chain is adjusted, lubed, and went for a test ride. :P
Re: Chain adjusters
Posted: Fri Aug 14, 2009 6:18 pm
by mszilves
delvryboy wrote:Ok, this thread actually helped. It got me out of the 90+ degree heat, sat in the AC, drank a half gallon of water, and had a smoke. Went back out and 15 minutes later, chain is adjusted, lubed, and went for a test ride. :P
Lol, sometimes a little break is all you need...
