Chain adjusters
Chain adjusters
Has anyone had these lock up on them? I can't get them to budge, the double nuts back right off. Wouldn't be a problem if I was trying to add slack to the chain, but unfortunately I'm trying to tighten it. PIMA.
'92 FZR600
Lots of Powder
Lots of Powder
Re: Chain adjusters
Ok, this thread actually helped. It got me out of the 90+ degree heat, sat in the AC, drank a half gallon of water, and had a smoke. Went back out and 15 minutes later, chain is adjusted, lubed, and went for a test ride.
'92 FZR600
Lots of Powder
Lots of Powder
Re: Chain adjusters
Lol, sometimes a little break is all you need...delvryboy wrote:Ok, this thread actually helped. It got me out of the 90+ degree heat, sat in the AC, drank a half gallon of water, and had a smoke. Went back out and 15 minutes later, chain is adjusted, lubed, and went for a test ride.
'03 Liquid Silver R6
'91 FZR 600
YZF swingarm conversion
Bridgestone BT-016s 110/170
