Need some help
Need some help
Hi all, I'm having problems with my 92 FZR600, It's blowing fuses for the instrument cluster about every minute. I re did some of the wiring because some of it was pretty shotty. Anyone have any ideas on what could be the problem? Thanks in advance!
'92 FZR600
Re: Need some help
95FZR600 wrote:re-trace the wiring harness make sure everything is good. Look up around the neck of the bike to make sure their are no cuts or anything.
checked that and the only wire thats cut is a blue one that I believe goes to the turn signals but everything else seems to be fine, any other ideas?
'92 FZR600
Re: Need some help
sometimes coroded connectors will cause a fuse to blow i had a running light in my rodeo that was coroded and it kept blowing the fuse i had to unplug all the lights and plug them in one at a time to find it
Re: Need some help
If i recall that's the headlight wire and it'll blow fuses quick if it is cut or loose.STP FZR wrote: checked that and the only wire thats cut is a blue one that I believe goes to the turn signals but everything else seems to be fine, any other ideas?
Re: Need some help
sweekster wrote:If i recall that's the headlight wire and it'll blow fuses quick if it is cut or loose.STP FZR wrote: checked that and the only wire thats cut is a blue one that I believe goes to the turn signals but everything else seems to be fine, any other ideas?
it just started happening yesterday and I've had the bike for about a week now and never had that happen.
I just went out and checked it, the fuse blows when I hit the brake, don't know if that stirs up anything
'92 FZR600
Re: Need some help
is it just the brake if so look for bare wires shorting on the frame
Re: Need some help
I checked all of the rear wires, is it possible i pinched a wire for the brake light when I synced the carbs and had it apart?
'92 FZR600
Re: Need some help
any things possible i would look for wires in pinch points. is it just with the brake light its blowing. if you have a multimeter you could check the polarity of the wiring. does it blow the fuse with both brakes. also check the bulb sockets mine rusted abit. also check the connection of the bulb pig tail. if its with the brake light i would say somethings shorting somewhere
Re: Need some help
ok so I disconnected the brake light wires and see if that was the problem, it was. So i plugged them back in, but now the brake light dims instead of get brighter when i pull the brake, what gives? the good thing is that I'm not blowing fuses anymore.
'92 FZR600
Re: Need some help
check the light sockets for rust
Re: Need some help
did that, they're clean and all wires are connected, no bare spots on any of themharo504 wrote:check the light sockets for rust
'92 FZR600
Re: Need some help
huh try to find the wiring diagram for it there should be one on this site some where and trace the wires does it do it with both the foot brake and the hand brake might narrow it down if its only one or the other
Re: Need some help
haro504 wrote:huh try to find the wiring diagram for it there should be one on this site some where and trace the wires does it do it with both the foot brake and the hand brake might narrow it down if its only one or the other
I've been looking at that, but it only happens when I pull the front brake, when I use the rear brake the brake light doesn't come on at all
'92 FZR600
