I got a problem
Posted: Thu Jul 09, 2009 8:16 am
by XxxYoOoOxxX
Alright well my 89 fzr is an OLD bike..And it runs great dont get me wrong..Its an awesome bike!
But I have noticed..When i stop at a light or stay parked (w/ bike on) the ( C & H ) The cold and hot thingy...Well my bike will go ALL the way up to H!!
I havent had it shut off yet on me..But it has been very close.. So i pulled over and then i tried to turn my bike on...It wouldnt turn on all i heard was like a fan..B/c it overheated i assume..
So this is what im thinking..When im sitting and my temp keeps rising..My fan doesnt turn on..It only turn's on when it reaches all the way to H..Which i dont think that my fan is suppose to stay off till then..
Or i think its my water pump..Oh yes and my anti-freeze looks fine to me everything connected u know..Its right at the line that says full..
So what do u guys thing it is? Help me out
Re: I got a problem
Posted: Thu Jul 09, 2009 8:28 am
by tkclow
Check the fluid level at the cap and make sure it is full (after it cools down of course) You will have to remove the fuel tank cover to check it.
Re: I got a problem
Posted: Thu Jul 09, 2009 11:27 am
by shredex
*cough* Manual Fan switch *cough*
its helped me tons...every time I stop at a light, I turn on the fan and it stays at about 175-185.
the auto fan on the fzr doesnt kick on till it hits about 220...225 is dangerous...230 your bike is about to take a s**t
Re: I got a problem
Posted: Thu Jul 09, 2009 12:43 pm
by the_finch
Another thing that it could be is a stuck thermostat. Takes a little more getting to than the other things mentioned, so I'd save it for last, but my bike quit boiling over and doesn't overheat as much since I replaced my thermostat.
One thing you have to remember about our bikes is that they were designed to move, so even a perfectly running FZR will have its temp go up when sitting at a light; the radiators are just too small to sit idling at a light for too long.
Re: I got a problem
Posted: Thu Jul 09, 2009 2:06 pm
by haro504
someone else ad a problem similer to this and it was i think the temp sensor was giving an inacurate reading
Re: I got a problem
Posted: Thu Jul 09, 2009 8:37 pm
by XxxYoOoOxxX
Yea i have heard many things..But its fine when its running..Its like below mid when running..But when i am stopped for awhile the temp will rise..
I have a guy that will check up on everything for 30$ should i do that
Re: I got a problem
Posted: Thu Jul 09, 2009 8:40 pm
by reelrazor
It's pretty normal.
And , like Shred-who lives in Florida-says.. a manual fan switch will prevent the bike from heating up THAT much
Re: I got a problem
Posted: Thu Jul 09, 2009 9:14 pm
by bweight
There's a number of things to check. Temperature sensor, thermal unit, thermal switch, temp gauge, thermostat, rad-cap, water pump... I'd been having this problem since I got the bike.. over 2 years now.. I changed EVERYTHING. coolant, water pumps, thermal unit/switches, gauges, etc... And I even ran the manual fan switch, tried running 2 fans. 1 in front and 1 in behind the rad.. Still no luck. When you check everything, and it's still doing it. It's likely time to check the headgasket.
Re: I got a problem
Posted: Thu Jul 09, 2009 10:03 pm
by XxxYoOoOxxX
Jeeze..Thats a lot of things to check LMAO..
Well it might be the temp indicator...Im not sure..Im taking it to a guy near me he said he'll check EVERYTHING for 30$..Then if anything is wrong we go from there
Re: I got a problem
Posted: Fri Jul 10, 2009 8:00 am
by csofos
haro504 wrote:someone else ad a problem similer to this and it was i think the temp sensor was giving an inacurate reading
+ 100
