So then it was time for a short test ride, considering I've already dropped 3 fuel pumps in this bike in less than 3 weeks trying to figure out the issues. I let her warm up for about 30 mind and the went to put it in first gear and it slammed in and died. So I adjusted my clutch lever and the spring mechanism on the front sproket cover. And I tried again.
This time it didn't slam in gear but it still died. I've tried second gear and same thing. My clutch switch was not working when I got the bike. And my kickstand switch is good. I've looked in the manual and it says to check continuity at the relay assembly on blue/yellow and sky blue. I got nothing. I don't know how to check my ignition box, nor do I gave the tools or place to check my clutch any farther than I already have.
I'm about to drop it off at a shop and tell them to fix it. But I know that will cost an arm and a leg. My old vr had a hole in it due to the previous owner neglecting any and everything on this bike. My neighbor did point out that my oil is low, but I'm told that shouldn't matter.
Any help on this is greatly appreciated. I've losing out on alot of time and money everyday my bike is down. I need to get her up and running again asap. Feel free to text or call me at 512-971-8543 if you care to talk more in detail.
