R6 Subframe With 03 undertail/fairing
Posted: Fri Jun 26, 2009 1:53 am
by XxxYoOoOxxX
Alright well i just bought a 01-02 R6..And now i have to buy a Undertail..And i was wondering if this would work
Now that part as the bottom with it..So i was wondering if that would be ok with this subframe
And with that would i need to buy a undertail?.. Or no i can just get something to stick my licenses plate on..And would i be able to put some lights on? Backlights?
Re: R6 Subframe With 03 undertail/fairing
Posted: Fri Jun 26, 2009 7:58 am
by XxxYoOoOxxX
Yea..See i dont want to really do that
..Just want to make it easy
Posted: Fri Jun 26, 2009 8:34 am
by tkclow
If you want to swap the subframe to the FZR frame it's not going to be "easy" they don't just bolt up. check with mrfreeze, we swapped an R1 and R6 subframe onto the FZR frame. You will need a welder.
Posted: Fri Jun 26, 2009 8:44 am
by XxxYoOoOxxX
Now this guy looks like he just bolted it..
Posted: Fri Jun 26, 2009 9:13 am
by tkclow
I don't know, maybe it's just me but that just looks kinda sketchy.
Posted: Fri Jun 26, 2009 11:25 am
by Genesis
tkclow wrote:I don't know, maybe it's just me but that just looks kinda sketchy.
I have to aggree..
I think the way I'm doing it is a little sketchy. the best way is to get a matching r6 tail, subframe, fender. cut off the fzr frame and weld on attachment points for the r6 subframe
Posted: Fri Jun 26, 2009 2:24 pm
by tkclow
Genesis wrote:the best way is to get a matching r6 tail, subframe, fender. cut off the fzr frame and weld on attachment points for the r6 subframe
95FZR600 wrote:I suggest cutting the old sub off and mounting the whole new one on.
May not be as "easy" but a whole lot safer
Posted: Fri Jun 26, 2009 2:26 pm
by shredex
thats target30's bike...i dont think he would have done it if it didnt work
Posted: Fri Jun 26, 2009 5:05 pm
by haro504
if you decide to sell that tail let me know
Posted: Fri Jun 26, 2009 5:06 pm
tkclow wrote:Genesis wrote:the best way is to get a matching r6 tail, subframe, fender. cut off the fzr frame and weld on attachment points for the r6 subframe
+1K on that not nice to have the seat you are sitting go away at 80MPH do NOT ask How I know !!!
Posted: Fri Jun 26, 2009 5:35 pm
by Genesis
yamaha_george wrote:tkclow wrote:Genesis wrote:the best way is to get a matching r6 tail, subframe, fender. cut off the fzr frame and weld on attachment points for the r6 subframe
ooouuuucchhhhh
Posted: Sat Jun 27, 2009 3:49 am
ooouuuucchhhhh
G,
It broke its tabs in an endurance race in the last hour and going into corners was use the frame rails as the seat moved with my butt & would hang up on a broken tab as I slid back up have to use extra force to get it back by counter pushing with the bike & my thighs. very hairy feeling for sure
Did a good impression of John Wayne's walk for a couple of days after
Posted: Sat Jun 27, 2009 1:46 pm
by shredex
then i would do what target did, because the subframe cant fail because the fzr subframe is still there...so even if the r6 subfrrame on there failed, then your still sitting on the fzr subframe so no worries there
Posted: Sun Jun 28, 2009 10:09 am
Shredex,
The BEST way is to make sub frame mounting lugs as per the later model bikes and mount that to the sub frame with bolts & safety pins or wires.
What happened to me is that the actual seat NOt the sub frame broke loose so as I moved arond hanging off the bike in corners it moved with me but gave grief when I tried to come back up right so it was snagged to my left at all time making right handers a real bitch as the seat dug in behind my knee with me wondering if it would suddenly snap free to the right pitching my body weight right on 120mph RH corners .
Not the most of relaxing rides, but buggered if I was gonna lose the 2nd place that our team had with a DNF of slip down way down with a pit stop.
