dual headlight question!
FZRrider09
Post by FZRrider09 »
Is both sides of the headlight supposed to be lit when on low beem or is it only supposed to be one. Mine only has one lit when in low beem but when I hit it to high both light up. thanks! RRBike
Re: dual headlight question!
FZRrider09 wrote:Is both sides of the headlight supposed to be lit when on low beem or is it only supposed to be one. Mine only has one lit when in low beem but when I hit it to high both light up. thanks! RRBike
FZR,
Sorry squire but there are various model duals around which is yours?
FZRrider09
its off of a 93, its the dual round ones from factory. If this doesn't help what do you mean by different ones? thanks for the help!
tkclow
Level 5.5
Level 5.5
Post by tkclow »
Both should be lit all the time, low and high. Sounds like you may have a low beam filament out on one side. New bulb and you should be all set.
92 FZR600
Dual Headlight Upper Swap
Clear Taillight w/LED Bulbs
More To Come
FZRrider09
Thanks for the help. I'll try that since I thought thats what might have been the cause of it not working. :yutugh2:
