So what are my options to get these guys from leaking? Any tighter and ill risk ripping out the threads again (which would be a whole new set of nightmares im sure) As much as i enjoy the smell of fresh oil on my exhaust pipe I dont think the locals would enjoy the constant trail of white smoke
Oil Line Stripped
Oil Line Stripped
So this winter i overtorqued and stripped the thread completely out of both ends for the banjo bolts (tired + not noticing the wrong setting on the torque wrench = Disaster). I used helio (sp?) coils to fix the thread and put on brand new copper washers. Im still having issues with leaking oil from both banjo bolts. I wouldnt be surprised if its because i did a piss poor job of installing the new threads (in the rain / hail we have been having no less).
Re: Oil Line Stripped
Pull the helicoils out and use a solid insert like:
http://www.timesert.com/
The coil type, like heli-coils aren't very good at keeping hot oil in, or out..and don't leave a good flat surface for the sealing washers to bear on.
icontender
I second the time insert. I have this on my buell and have had no problems. Its stronger than factory seal.
