electrical issue
Posted: Fri Jun 05, 2009 1:52 pm
So i got myself a project fzr600r on craigslist. this bike was in pieces with a large hole in the motor from a connecting rod coming loose. so i trashed the motor and got me another one. now after getting the bike almost complete, I was able to get a battery and make sure all my electrical worked. well it did. So when i was done playing around with it, I put it on a trickle charger that also has storage mode. This charger has an indicator light that tells you the status of the battery. So after two days the battery was still charging. I thought it was the battery so i took it back and got a replacement. well after the second battery did the same thing, I knew it was not the battery. Now when i got the battery, I put it up on a wooden table and charged it completely. no problem there... then i used it and wanted to keep it charged... there is where my issue started. What would cause this? I was thinking bad ground but where does this bike ground? I know there is one that runs to the engine from the battery negitive. but other then that im lost. thanks for your help.
