isnt that a three peice header?(Pipes 1&2, 3&4, and the mid?)
someone on the board has it...I remember the pics when they had it taken apart and painted.
edit*
Check with board member "mrfreeze5" I believe he has the same header as you.
+1 D&D got one on my bike. If you can weld or know someone who can weld the three pieces together, it makes getting in on the bike alot easier and also stops it leaking around the joins.
