Starting The Bike for the Summer, and it wont turn over
Posted: Sun May 03, 2009 8:21 pm
by Netter
Since I finally go the bike up and running and the clutch replaced, I have taken it out a couple times for some short rides and it worked great! but now it has been about 8 weeks since it last started and now it wont turn over, battery works fine, tank is full, but it seems like its not getting any fuel in the bowls, the pump picks up gas but then it wont start :(
hopefully it will start soon
Re: Starting The Bike for the Summer, and it wont turn over
Posted: Sun May 03, 2009 8:30 pm
by cad600
Got spark?
Check all of the fuses?
You say it won't turn over. Meaning what? The starter motor won't turn on or the bike won't fire up?
Posted: Sun May 03, 2009 8:39 pm
by Netter
I'm going to check the spark again in the morning, and all fuses are good, it wont fire up, it sounds like its getting close but then it gives up
Posted: Sun May 03, 2009 9:42 pm
by reelrazor
Dry or replace the plugs, air out the cylinders. Try again with full-charged battery.
Posted: Mon May 04, 2009 3:17 pm
by Netter
Spark Plugs ended up being the problem, after an oil change it runs great ! thanks !
