wiring harness and cable routing
Ok, I guess I'm a dumba$$, I cant figure out how this wiring harness and throttle cables are routed through the frame. If some has some pics or diagrams of how this thing is routed , could you please post them before I go nuts trying to figure this out.....if you can just take a pic of your wiring harness and cables near the frame rubber holes so I can see what goes though which side.... thanks
Re: wiring harness and cable routing
Your main harness runs through the left side frame if your sitting on the bike. Your headlight harness stays up front and runs along the bottom. Their are tabs that fold over for the front harness and the main harness. Hope this helps. My bike is all covered up due to some painting today in the garage.
