Brake light doesn't work
Posted: Tue Apr 07, 2009 12:31 pm
by BAT
The light works, but no brake light, the turn signals are integrated into it, but they work. The switches are working.
Re: Brake light doesn't work
Posted: Tue Apr 07, 2009 12:51 pm
by tkclow
Brake light switch may be out of adjustment
Posted: Tue Apr 07, 2009 1:15 pm
by BAT
It clicks and completes the signal.
Posted: Tue Apr 07, 2009 1:27 pm
Is it a stock tail light you integrated or is it an aftermarket one?
Posted: Tue Apr 07, 2009 11:30 pm
by BAT
The previous owner did it, it appears to be stock tailights. I'm guessing the turn signals are using the same wire path to the bulb? Maybe that junction is where the problem is. I'll look in the morning or check power at the switches.
Posted: Tue Apr 07, 2009 11:33 pm
by shredex
check the switch itself as well...make sure the two plugs are plugged in and plugged into the right one
Posted: Wed Apr 08, 2009 1:41 pm
by BAT
The problem is in the little black integrator box. Got power from the brake switches to the box, but not out. It probably shit out when the VR was putting out 18 volts. So I guess I need a new integrator.
Posted: Wed Apr 08, 2009 2:15 pm
BAT wrote:The problem is in the little black integrator box. Got power from the brake switches to the box, but not out. It probably shit out when the VR was putting out 18 volts. So I guess I need a new integrator.
Intergrator box huh? It's probably just a trailer light pack. A lot people use them to integrate the rear lights
Posted: Wed Apr 08, 2009 3:02 pm
by BAT
I just went to radioshack and picked up some of the relays for the "poor man's integrator". But after realizing my solder and gun are too big, had to buy that too. Ended up spending 40 bucks for a poor boy mod. All should be well now once I figure the wiring out. Not excited about it.
