Handle Bars
dreman
Handle Bars
Post by dreman »
I finally took my bike for a nice long decent ride on Saturday after the bike had been sitting in the garage for the past month. As I was going round one of the corners the was fu*king gravel on the road and the whole bike just slipped out from under me and right smack into a tree. My front fairing is smashed, the fairing stay is bent to shit. all left side original plastics are shit as well...... :swear just one of them days...... :ermm:
after looking at the bike, i was considering going streetfighter. I wanna know how do you mount the handle bars on the triples. Do you drill holes in the triple to mount them or do you change the triple. I was thinking of using some sort of motorcross handle or something like that. If anyone here who has done it can point me in the right direction, I would greatly appreciate it.
thanks
ragedigital
4000+ Posts
4000+ Posts
Re: Handle Bars
Post by ragedigital »
Here is one way - the whole triple: http://www.spieglerusa.com/cfm/sbk.cfm
And another is to buy just the risers and bolt them on. I think Nate did that or maybe Spyder...
sweekster
Re: Handle Bars
Post by sweekster »
The cheapest way is to drill the top triple clamp and then you can mount what ever risers and handle bars you want. I've seen a few people do this with no issues. If you don't want to do that then get them from another bike. The Yamaha XJ 600s Diversion (See Below-Known as the Seca II here in the US) used a very similar front end to the FZR and the top clamp was already set up for risers and handle bars. You find a top clamp from one of those and it should be a bolt on swap.
ragedigital
4000+ Posts
4000+ Posts
Re: Handle Bars
Good call on the Seca! I'd be willing to bet they used the same forks for many years.
sweekster
Re: Handle Bars
Post by sweekster »
The forks weren't exactly the same. They had different front fenders and the Seca only had 1 front brake- which I would think that little short coming can be remedied by possible swapping the fork lowers with FZR ones. But both had 38mm forks and use the same stem.
Re: Handle Bars
Post by thatkid »
ragedigital wrote:Here is one way - the whole triple: http://www.spieglerusa.com/cfm/sbk.cfm
I did it this way, but I made my risers. I can't afford to buy things. :ermm:
dreman
Re: Handle Bars
Post by dreman »
thanks guys..... would love to buy the whole set but with the aussie dollar being the way it is i might have to look for the seca.
thanks again
Re: Handle Bars
sweekster wrote:The forks weren't exactly the same. They had different front fenders and the Seca only had 1 front brake- which I would think that little short coming can be remedied by possible swapping the fork lowers with FZR ones. But both had 38mm forks and use the same stem.
Sweekster,
I seem to remember that I did a double caliper conversion on our Seca drag bike just drilled the wheel on the casting points that were there but not used & adding a disc.
As I said a LONG time ago so I could be wrong and our Model (west indies ) could have been from anywhere else in the world we had all sorts arrive including what was supposed to be Japanese only with the idiot speeding light
TXFZR600
Re: Handle Bars
Post by TXFZR600 »
Seca II top clamp is a direct bolt-on.
foxeyepete
Re: Handle Bars
Post by foxeyepete »
Hi i see you used the seca/xj600 top yoke ,did you have to change any wiring/cables,brake hose as well cheers Peter
Re: Handle Bars
foxeyepete wrote:Hi i see you used the seca/xj600 top yoke ,did you have to change any wiring/cables,brake hose as well cheers Peter
Pete,
I doubt it unless you made the bars real long .Your old clip ons were above the yoke at the very top of your fork legs if you see what I mean.
ludikris
Re: Handle Bars
Post by ludikris »
I just bought a pro taper universal set of risers and a fat bar for $100....
the guy is on ebay but I called him directly and ordered them...
http://cgi.ebay.ca/02-2822-Pro-Taper-1- ... 194wt_1137
Re: Handle Bars
ludikris wrote:I just bought a pro taper universal set of risers and a fat bar for $100....
L,
1.125" bars, will the original switches & throttle action work on that size I was always under the impression that Yamaha (& most jap bikes) were smaller in diameter than that.
I would go and check mine but am still laid up in bed !
Re: Handle Bars
7/8" is my understanding for just about every bike on the planet (except High Density - I mean, Hardly Ableson).
delvryboy
Level 5.0
Level 5.0
Re: Handle Bars
Post by delvryboy »
I believe the fat bars taper to 7/8 for the controls. As long as your riser fits the thicker bar, you should be fine.
'92 FZR600
Lots of Powder
