Fork Seals reusable or not ?
Posted: Sun Jan 25, 2009 10:25 am
by Dragon
Ok, here's my question.
Has anyone reused fork seals that were not leaking?
I'm about to change the lower tubes on my forks to the four piston type(93), and just put new seals in the forks(89) on the fizz last year. The seals in the new forks are also not leaking, but one of the upper tubes is bent. After breaking the forks down to do the swap, does anyone think I can reuse my seals, or do I need new ones?
Re: Fork Seals reusable or not ?
Posted: Sun Jan 25, 2009 10:38 am
by shredex
im sure you can. people just would buy new ones for $15
but if they didnt leak, then go for it.
you doing a newer tube to fit r6 calipers?
Posted: Sun Jan 25, 2009 10:45 am
by Dragon
Yeap!
Anyone else got thoughts on reusing seals?
Posted: Sun Jan 25, 2009 1:45 pm
I would change them out. You don't want to have to change them out a month from now, ya know?
Posted: Sun Jan 25, 2009 1:58 pm
by megaloxana
Replace them. For the low cost of the seals and since you already have the forks apart it would just be efficient.
Posted: Sun Jan 25, 2009 3:12 pm
by ANCIAL
i would change them out also. its only fifteen bucks. and then you will know for sure that there are no leaks. to me thats alomost like reusing an oil filter
Posted: Mon Jan 26, 2009 5:28 am
ANCIAL wrote:i would change them out also. its only fifteen bucks. and then you will know for sure that there are no leaks. to me thats alomost like reusing an oil filter
+5 to all for the change the seals advice .
The only time I have not was a disaster.
Err silly question why change the lower tubes ( unless damaged ) to handle the 4pot calipers I just bolted my bling blue stars in place with new teflon & stainless steel hoses of course.
Posted: Mon Jan 26, 2009 7:34 am
by 95FZR600
megaloxana wrote:Replace them. For the low cost of the seals and since you already have the forks apart it would just be efficient.
Posted: Mon Jan 26, 2009 2:31 pm
by Dragon
yamaha_george wrote: /quote]
George, I have a 89 fizzer. (2 pot forks)
The blue pots will not fit on those forks. I purchased a whole setup for an R6 for cheap a while back, so I wanted to put the blue pots on the fizz.
Posted: Mon Jan 26, 2009 2:52 pm
by haunter
change the seals
Posted: Mon Jan 26, 2009 2:55 pm
by Dragon
I will guys, just wanted to know if anyone did it before.
