wont idle need help !
Posted: Sat Jan 24, 2009 10:47 pm
by cypher333
the bike wont idle, so heres what its doing. It will start with the choke on and warm up choked but once the choke is let go it will slowly die. With the choke on I can rev it, but it takes a while for it to rev after i turn the throttle. then when i let go of the throttle it will very slowly drop back down to an idle WITH the choke on. it will not start at all warm without the choke...whats the problem ? fuel mixture too lean ? whats wierd is that it has a lag when i throttle it and slowly drops RPM after throttle close. screwy
Re: wont idle need help !
Posted: Sat Jan 24, 2009 10:55 pm
by megaloxana
Well could be a few things. It does sound like you're running lean. First I would make sure that you don't have any vacuum leaks. Check the rubber boots that the carbs sit on for cracks. Make sure they're on tight if recently took the carbs off because it can be hard to get them to seat back. Also try richening up your idle mixture screws. You can also try raising your idle once your bike is warmed up.
Posted: Sat Jan 24, 2009 11:16 pm
by cypher333
they were taken off recently, i'll check that thanks
Posted: Sat Jan 24, 2009 11:33 pm
by megaloxana
If you're having trouble getting the carbs back into the boots, you can make them more pliable by dipping them in hot water or taking a heat gun or hairdryer to warm them up.
Posted: Sat Jan 24, 2009 11:43 pm
by cypher333
yeah i had a hell of a time getting them back on
Posted: Sun Jan 25, 2009 1:20 am
by 95FZR600
Pull the tank and see if all your cables are good to go and tight. I had this problem once and the choke and throttle at the carbs were loose. Start there and check the rest like mega listed.
Posted: Tue Jan 27, 2009 9:58 pm
by cypher333
ok so i seemed to have fixed the idle problem but it still revs up and hangs the rpms for a while before it drops back to idle. what the hell is wrong with this thing :swear
Posted: Tue Jan 27, 2009 11:18 pm
by megaloxana
cypher333 wrote:but it still revs up and hangs the rpms for a while before it drops back to idle. what the hell is wrong with this thing
did you try messing with the idle mixture screws?
Also I recommend you do a carb sync if you haven't done one yet.
Posted: Wed Jan 28, 2009 12:43 am
by cypher333
no not yet. should i just turn them out 1 turn ? to richen it ? or lean it out ?
Posted: Wed Jan 28, 2009 1:24 am
by megaloxana
cypher333 wrote:no not yet. should i just turn them out 1 turn ? to richen it ? or lean it out ?
1/2 turns to lean it
Posted: Wed Jan 28, 2009 1:43 am
by cypher333
to lean it is clockwise right ? I'll try it in the morning thanks for the help
Posted: Wed Jan 28, 2009 1:44 am
by megaloxana
cypher333 wrote:to lean it is clockwise right ?
correct
