slow starter ?
cypher333
slow starter ?
Post by cypher333 »
I just recently put the engine back together after blowing a rod as well as replacing the starter "peanut" cover. Well when I hit the switch to start it all i hear is the pistons going up and down very slowly. Could this be a bad battery, ground to the engine, or is something wrong with the starter cover ? :headscratch: The starter cover was pretty straight forward to put back on so i doubt its that...maybe its the ground to the motor :headscratch:
sweekster
Re: slow starter ?
Post by sweekster »
How strong is the battery? Try jump starting from a car...
Re: slow starter ?
sweekster wrote:How strong is the battery? Try jump starting from a car...
Sounds def like the battery as it has been sitting awhile unless you had it on a bat. tender.then it may need replacing or topping up.
95FZR600
Re: slow starter ?
Post by 95FZR600 »
Could be any of the ones you mentioned. I would start with th least expensive.
jumping it over
check the grounds
new battery
Re: slow starter ?
95FZR600 wrote:Could be any of the ones you mentioned. I would start with th least expensive.
95,
we are bikers we ALWAYS go for the cheap option first <BG> :whistle
RCPlayland
Re: slow starter ?
Post by RCPlayland »
also check your connections on your starter solenoid. Clean them and the battery connections.
I also un plug my headlights for day use... or weak battery. I know they shut off when ya hit the starter button... but when your thumb is off the button they pull juice.
Couldn't hurt.
http://www.myspace.com/rcplayland <-------Click here for myspace webpages of me
megaloxana
Re: slow starter ?
Post by megaloxana »
Yes very good chance its your battery. However you did mention you had the engine torn down, make sure your mechanical timing is correct too.
cypher333
Re: slow starter ?
Post by cypher333 »
thanks for all the info guys... well its not the battery just got a new one from a friend. i'll check grounds and solenoid when i get some time. thanks :cheers:
csofos
Level 4.5
Level 4.5
Re: slow starter ?
Post by csofos »
95,
+1.000 :whistle
