few other things about my bike
Posted: Mon May 19, 2008 2:38 pm
by ian
I still have high oil consumption. I had to refill a few days ago, and I just did an oil change 2-3 weeks ago, or about 1000 miles ago. I doubt its a leak, as I haven't seen any puddles. Any ideas?
Another question, it seems my bike is farting out carbon. I first noticed it on the fender of my car (probably from backing out of the garage) and then saw some more on the garage door (most likely from letting my bike idle in front of it). It makes a splatter pattern like dirty road water. I should've taken pics, but I'll get a paper plate or something and hold it behind the can to see and I'll take pics of that.
Could these problems be related? what do I need to do for each?
Re: few other things about my bike
Posted: Mon May 19, 2008 3:17 pm
by Dr Rockso
you could be burning oil , does it smoke when you rev it up ? my suggestion is to do a compression check and see if one or all of the cylinders is low .
Posted: Mon May 19, 2008 11:06 pm
by ian
sorry, but how do I do a compression check?
Posted: Tue May 20, 2008 12:00 am
by Dr Rockso
you can have a shop do it , or you can buy a compression tester , it a got a dial and screws into the spark plug holes .
Posted: Sat May 24, 2008 2:33 am
by ian
once again, I am having to refill oil tomorrow. :mad(
Posted: Sat May 24, 2008 5:27 pm
by fropleyquark
look at the bright side, you always have fresh oil! J/K definitely do a compression test. Thatll let you know. I would suspect youre burning oil.
Posted: Sat May 24, 2008 6:11 pm
by orlandoFZR
have you tried a different kind of oil? With rotella my bike burned @ quart every 500 miles and had pretty smoky startups, I switched to valvoline it only burns like a few ounces now, and very little if any smoke on startup.
Posted: Thu May 29, 2008 7:40 pm
by ThisEndUp
does your bike rev smoothly and steadily to red line (or almost) ?
or does it climb slowly over around 5000 revs?
