A little while back George (yamaha_george) posted some wheel bearing specs to use for converting from the 15mm stock front axle to beefier 20 and 25mm front axles.
As I understand it, the following would be needed for the fat front axle mod:
New front wheel bearings
New front wheel spacers (both the ones between the bearings and the ones between the fork/wheel/speedo sending unit)
Speedo sending unit
Front Axle
Fork legs bored to accept the new axle
First thing's first: why? With the fatter front axle is less prone to flex like the stock axle is, allowing both forks to work in tandem better and thus do their job better.
Here's what a little spare time can do for you....
According to the microfiche, a 1997 YZF 750 used a 20mm front axle. This helps, as the bearings used on this bike are the ones George researched for use on the 20mm axle conversion (6004-2RS). Another big help is that it appears that the bike uses a cable-driven speedometer, which means there should be a way to adapt the sending unit for use on the FZR600.
The only hiccup in using the whole front axle assembly is the front axle itself. It's designed for the upside-down fork assemblies that the YZF 750 uses, and it would be pretty tough to convert that particular axle. Solution? The 1997 Bandit 600 uses a 20mm rear axle of the same style as the FZR front, though it is safe to say it is alot longer. Cut it down and re-thread the end to the custom length needed and you're good to go (after getting your fork legs modified, of course).
I currently don't have the funds to pursue this mod myself, but thought I'd share some of the knowledge I'd collected in my research in case somebody else had the time/money to do the write-up on this.
