Shift light
the_finch
Level 8.5
Level 8.5
Shift light
Post by the_finch »
I haven't seen any thread on this so far....
I was thinking of putting a shift light on my bike set for just below redline....since I got the carbs working well again I tend to use a little more throttle than I used to... :whistle ....and I accidentally go past 11.5k once a ride.
I was thinking of using one of these.
Does anyone think it'll work standalone, or do you think I'll need a seperate rpm activated switch for it?
1997 FZR600RJ
megaloxana
Re: Shift light
Post by megaloxana »
That one is a standelone light. It has a knob on the back where you select your RPM. Its got 3 wires: ground, 12v, and tach signal. Should work...i say get it and report back. This is something I wouldn't mind getting for mine either, but I wanted one of the skinny ones. Unfortunatly most of those require a seperate control module.
bucket
100+ Posts
100+ Posts
Re: Shift light
Post by bucket »
I got a shift light... :whistle I'l have to hook it up and see. can anybody tell me the wire for the tack signial? WOOT
95FZR600
Re: Shift light
Post by 95FZR600 »
Should go to your CDI.
Thats a great price. Let us know when you get it.
What do ya'll think about a LED Gear indicator? I would like to add one of those to.
shredex
Re: Shift light
Post by shredex »
95FZR600 wrote:Should go to your CDI.
I posted a thread with gear indicators.
viewtopic.php?f=11&t=2425
R3TARD
Level 4.5
Level 4.5
Re: Shift light
Post by R3TARD »
that one looks awful big though. maybe just me
1992 FZR 600
Yoshi exhaust
K&N pods
Airtech R1-kit
02 R6 fork swap
02 R6 Swingarm
520 chain conversion
07 R6 controls
Vortex R6 clipons
07 R6 radial master
2003 CBR 600rr
bone stock
the_finch
Level 8.5
Level 8.5
Re: Shift light
Post by the_finch »
R3TARD wrote:that one looks awful big though. maybe just me
It probably is too big. 1.5" dia. x 5" long. The big thing would be that it has the rpm switch built in. At that price you could buy them and rip them apart for the rpm switch. The cheapest alternative rpm switch unit on eBay was about $45 last time I checked and wasn't adjustable.
In theory you could use any old bright LED or regular bulb and just use the unit to trigger at the right rpm. my2cents
1997 FZR600RJ
PIMPMYFZR
Re: Shift light
Post by PIMPMYFZR »
that would be pretty kool if u could somhow drill a hole into the rpm tach and pop a led light in the middle and set it up to light up when to switch out ..
i like the LED indicators they dont seem to expensive but i like timing when to switch rather then being told or shown when to ..
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
bucket
100+ Posts
100+ Posts
Re: Shift light
Post by bucket »
^^ like this? its a boost gauge but I think its what ur talking about.
http://www.impconcepts.com/vwpassat20psiboostgauge.htm
PIMPMYFZR
Re: Shift light
Post by PIMPMYFZR »
bucket wrote:^^ like this? its a boost gauge but I think its what ur talking about.
yea just not all lettered out just a little led that is hooked up to a senser .. but the indicator is pretty pimp ..a good friend of mine has what your talkin about in his 550hp audi S4 ..
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
bucket
100+ Posts
100+ Posts
Re: Shift light
Post by bucket »
still cant find a tak wire?
sweekster
Re: Shift light
Post by sweekster »
If you look at the back of the gauge cluster you'll see a harness plug going into the tach. There should be the gray wire coming out of that harness plug and it should go all the way back to the CDI and remain the same color all the way through. You also can get the signal by wrapping the signal lead to the shift light around spark plug number one 5 times.
FZR600 section in our WIKI that contains the wiring diagram.
shredex
Re: Shift light
Post by shredex »
the shift light is rather large...found a pic of one on this guys fzr600 (MOTORHEAD from archives).
its on the upper right
this guy also needs to calm down with all the gauges...lol
megaloxana
Re: Shift light
jeez its like a military control room in his dash. Anyway Im sure with some soldering and basic electronic know-how you could downsize to a smaller light using the internals from the previous mentioned shift light.
bucket
100+ Posts
100+ Posts
Re: Shift light
Post by bucket »
I hooked mine up but it didn't work. it could be broken.... :dubious: I took the casing apart to check the bulb and it wouldn't be hard to setup some wires off the light leads to a flashing led on the dash and mount the rest of the light under the seat... I found a trail tech Vapor dash kit :banana: locally for cheap so I think Im going with that setup if I can afford it.
