wierd oil leak maybe?
Posted: Mon Dec 08, 2008 10:20 pm
by deathcomesarippin
I have noticed on the right plastic underneath the driver seat looking from the back of the bike some kind of liquid that looks like it is being sprayed on, I checked the brake fluid and oil levels and both are good, im guessing maybe its a little bit of oil being sprayed out at a time but I odnt know where from. ill get some pictures soon to make this easier
Re: wierd oil leak maybe?
Posted: Mon Dec 08, 2008 10:28 pm
by shredex
finally another one from florida!!!
anyways...Im guessing its a oil leak also...check where all the seals are that contain oil. (both right side engine covers, head gaskets)
could also be coolant coming from a hole in the hose...
one way to test your radiator hose is to turn your bike on and rev it to a high rpm and if theres a hole then coolant will be sprayed out of it...
Posted: Mon Dec 08, 2008 10:41 pm
ok will do first thing tomorrow I replaced the valve cover gasket about a month ago but ill still check it out to, thanks
Posted: Mon Dec 08, 2008 10:43 pm
by shredex
deathcomesarippin wrote:ok will do first thing tomorrow I replaced the valve cover gasket about a month ago but ill still check it out to, thanks
yes, but it will still leak if not tightened up enough :thumbsup:
what part of FL you live in???
Posted: Tue Dec 09, 2008 10:35 am
by reelrazor
Fork seal
Posted: Tue Dec 09, 2008 12:58 pm
nah its not a fork seal I looked at it today and it was the head gasket so I took it off and put more sealant on it i hope this should work, but I live in plant city close to tampa
Posted: Tue Dec 09, 2008 2:15 pm
by shredex
deathcomesarippin wrote:nah its not a fork seal I looked at it today and it was the head gasket so I took it off and put more sealant on it i hope this should work, but I live in plant city close to tampa
just make sure you tighten them enough.
they have a spacer that will allow you to tighten it without overtightening it...
tampa is close to me
