ok so all my bikes ive owned so far have specifically said use premium unleaded gas... well after googling yamaha fzr600 i was reading an article where it said use normal 87 octane gas... so im confused and i was just curious what everone else is using... please take you time as i just filled my tank with 91 octane so its going to take alittle to empty it... thanks for all yuor info...
ps: the only upgrade i have is a vance&hines pipe... thanks...
gas in an 90 fzr 600
- the_finch
- Level 8.5
Re: gas in an 90 fzr 600
I use premium (93 octane here in Dothan, AL), but I have a Factory Pro Ignition Advancer, and am worried about possible detonation. You should probably be good with just regular unleaded.
1997 FZR600RJ
- mike94fzr600
- Level 4.5
I use regular unleaded 87
my rides
2000 chevy z71 4x4
1994 fzr 600
2000 chevy z71 4x4
1994 fzr 600
My FZR got fed 87. Tried higher octane and didn't really notice a difference aside from a lighter wallet and slightly worsened performance.
PAFizzer600
please please please please only run the recommended 87.
i run only sunoco or shell fuel and she doesn't feel quite right with anything more than 89
87 is the smoothest and best all around performance
Like he said ^ . Run the lowest octane you can get away with(no ping? it's good enough).
I have ign advance and have tweaked my cam timing for midrange, and jet quite lean. 87oct is good 85% of the time, but will ping high load, high revs so I use 89.
Run as low an octane with out pre-ignition/detonation as you can. If you're on pretty much stock setup run the 87 as the manual recommends. For folks that have their motors twisted up a bit tighter they will likely need a higher octance. Somebody really need to do a sticky on octane numbers and what they really represent. The higher the number is not necessarily better fuel. And AIRC up to 10% blended fuels are also acceptable in these motors. But again check the manuals that are online as they tell you there if your original owners manual is MIA.
