dog bones
dog bones
Is the steel you find at places like Lowes, Home Depot strong enough for dog bones if not where should i be looking to buy the metal from? And another thing what about cutting the stock bones and rewelding them then reinforce them on the sides?? Or what if i redrill a new hole in the stock bones?
- shredex
Re: dog bones
I think you need to find some tempered steel. aluminum is known to snaperawtik wrote:Is the steel you find at places like Lowes, Home Depot strong enough for dog bones if not where should i be looking to buy the metal from? And another thing what about cutting the stock bones and rewelding them then reinforce them on the sides?? Or what if i redrill a new hole in the stock bones?
You can find a couple diff. metals at lowes, just ask to know what kind of metal it is. and make sure its thick enough. dont get sheet metal.
1/2 inch thick should be good
Re: dog bones
i buy steel all the time just to have on hand for when i weld something or rig something together. I know it comes in all kinds of thickness and width is usally inch up to like 2 inches wide. Im just wondering if its strong enough cause the stock bones are pretty thin but must be storng metal.
Re: dog bones
How about this?
I have a set on hand. PM me.
EDIT by Y_G as Moderator :-
I added the following photo so that others at a later time can see what weld is required to do this
PLEASE read ReelRazors post in reply to mine to see the SAFETY issues involved and the precautions he took as a Professional Welder !!!
Re: dog bones
are these supposed to be adjustable dogbonesreelrazor wrote:How about this?
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
Re: dog bones
1/2 inch is too thick, stock are 1/4 inch I think
SOLD
SOLD
Re: dog bones
Stock are just under 1/4" thick. I use 1/4" aluminum when I make new ones. 6061/7075/2024 it's all strong enough. For steel I would say 3/16" thick is fine. That may be what the stock bones are.
Re: dog bones
Hmm while certainly an idea, the loads on those rather small weld areas in the picture I personally would worry about.reelrazor wrote:How about this?
I would be sure and make the weld beads the full length of the hex + top and bottom.
The allen key headed bolt is just plain scary (and does not allow true adjustability without partial dis-assembly.)
How ever I would weld a second piece of hex in its place with a clearance hole thro it and weld as the other one.
Then using a high tensile steel bolt with more threads, put it first thro the clearance hex, then a nut then adjust my dogs to suit by screwing it into the lower hex and lock the position with the middle nut.
That way I hope I would have made an on the move adjustable ride height assembly, that can take the strain.
PS The above description is mine but the idea is from an early GP test bike I saw back in the 90's.
RealRazor neat idea and thanks for reminding me, but please beef up the assembly I hate bad news about bikers.
Re: dog bones
Let me allay you fears, george.yamaha_george wrote:Hmm while certainly an idea, the loads on those rather small weld areas in the picture I personally would worry about.reelrazor wrote:How about this?
a) the welds were performed by an experienced certified welder (me: A.W.S.- with cert in FCAW, GMAW, SMAW-all positions. TIG in two positions)
b) welds are full length, wrapped corners.
c) weld is cjp where possible.
d) grade 8 allen bolt which has larger cross section than the original dogbone (which is A36 steel btw-low midgrade mild steel)
e) process and welds were initially inspected by my shop's AISC certified Weld Process Inspector.
f) my shop's lead project manager/steel fabrication engineer (who also rides) liked the idea and saw no issues
g) after a couple hundred miles , the ones on my bike were tested using a dye penetrant method with no cracks or strains except for micro-cracking radially
around the original pivot bolt holes (which were almost certainly caused in the {original OEM die punching process)
h) I have now close to 2000 miles on them with no further distress
i)The weakest link (literally) in the whole rear suspension are the bolts on which the dogbones hang at the swingarm and at the relay arm which are subject not only to tensile loads (such as the dogbones), but also to shear stress. Those bolts are of the same grade and smaller diameter than the hardware I used.
i) I can perform adjustment in less than five minutes with the bike on the swingarm stand and a scissor jack between the tire and seat subframe-and do whenever I have a pillion rider-by removing just the bottom bolt and counting out turns (one turn =4.5mm of tail rise). The units I make allow about 60mm of adjustment in 11 steps (allowing thread overlap at junction equal to 1.5 diameters)
Now on to some of my observations.
I have seen for sale:
Dogbones re-created using aluminum, the grades of some of which is a work hardening alloy (and if it was a a good idea would have been done by Yamaha) patterned after the orig steel units.
Adjustable dogbones with multiple holes, in steel, stainless(also work hardening), and aluminum with 2mm or less of material between the holes. Which, btw, require more "partial disassembly" to adjust
Thanks for your opinion (and concern) tho.
Re: dog bones
Not true. Yamaha's goal is profit as is any company. Steel is roughly 5 times cheaper than aluminum. That's a better margin for them.reelrazor wrote: Dogbones re-created using aluminum, the grades of some of which is a work hardening alloy (and if it was a a good idea would have been done by Yamaha) patterned after the orig steel units.
Re: dog bones
Yeah, you are right. Steel is cheaper. My point was that work hardening grades of alloy are not a good idea in any application where cyclic stress is an issue.thatkid wrote:Not true. Yamaha's goal is profit as is any company. Steel is roughly 5 times cheaper than aluminum. That's a better margin for them.reelrazor wrote: Dogbones re-created using aluminum, the grades of some of which is a work hardening alloy (and if it was a a good idea would have been done by Yamaha) patterned after the orig steel units.
Re: dog bones
ReelRazor,
Good, I am glad your engineering skills live up to your nickname and you have tested the goods in a scientific manner and are as safe as you can be on a bike.
I see so much work that while it looks OK you have a nagging doubt about how safe it is, being a belt & braces engineer I do my best to warn others of the likely pitfalls of their design, I have survived nearly 50 years of biking and my own & other engineers tinkering so I know how good life can be and how catastrophic even the slightest corner cutting can be .
Like you I warned one lister who had a pair of multi-hole dog bones and their potential for failure. One thing about this list the members do appreciate sound tech advice , PLEASE always feel free to give it, that is what makes the group so special.
- shredex
Re: dog bones
after riding on those for awhile, the thread on the bolts might deform and you wont be able to unscrew it anymore
Re: dog bones
I'll say again...I have close to 2000 miles on the set on my bike.shredex wrote:after riding on those for awhile, the thread on the bolts might deform and you wont be able to unscrew it anymore
I have adjusted (to raise the tail) them each time I have taken a passenger, and then reset the ride height for myself solo six or seven times in those miles.
Tensile failure (breakage)of a 3/8" grade 8 bolt is 12,360 lbs. Yield (stretch resulting in deformation) occurs about 20% lower which equals about 9800lbs.
My bike and I weigh about 590lbs.
I would need a load of 16g's to stress ONE of the bolts to yield.
Keep in mind there are two acting in tandem.
In other words:
Not very likely a valid worry.
Re: dog bones
x2 on kids comment about cost for Yamahareelrazor wrote: Dogbones re-created using aluminum, the grades of some of which is a work hardening alloy (and if it was a a good idea would have been done by Yamaha) patterned after the orig steel units.
7075 T6 is marginaly less strong than 403 Stainless, which is stronger than the whatever cheap ass crap metal the stock dogs are made of
I have nothing bad to say about yours, its a good idea, if I needed that kind of adjustability.
SOLD
SOLD
