2) the bike runs excellent, but the idle wonders while sitting. It is set at 1500, but wonders to 1900 and back, what gives.... yes did a sync with an actuall mercury carb tune 2 tool. Any suggestions would be appreciated.
Thanks
Tried it and B12 Chemtool. Had the carbs tore down and built back up.....zero9243 wrote:Try some seafoam to simmer down that idle problem.
+1 on checking for leaks.megaloxana wrote:air leak..try checking for cracks in your intake boots(between carbs and head) and make sure your airbox is properly secured(can be a real PITA)
Well i'm 100% sure that this tail is '99-'02 model R6. I had an R6 for a couple of months sometimes and it's familiar to me. After '03 Yamaha make changes on R6.95FZR600 wrote:Would help if you took a good pic of the rear tail area. Kind of looks like 99-02 R6 but cant be sure with only a 1/3 of it showing.
