Im doing the tail swap r6 style....
Posted: Sat Oct 11, 2008 8:24 pm
by blackeyesandbruises
I got 3 different years lined up, which year is the easiest swap that works the best for my 91?
Re: Im doing the tail swap r6 style....
Posted: Sat Oct 11, 2008 8:27 pm
by 95FZR600
Whatever skills you have you make anything work. I have the 99-02 but I have seen 03-05. Its up to you. Any of them will work with modifying.
Posted: Sat Oct 11, 2008 8:29 pm
when you did it did u need any specialty tools?
Posted: Sat Oct 11, 2008 8:34 pm
by PIMPMYFZR
a dremel or cutting wheel will help alot
Posted: Sat Oct 11, 2008 8:35 pm
Sweet so no other major tools need just something to cut and grind with...I like it.
Posted: Sat Oct 11, 2008 9:51 pm
by nynoah
there is welding involved.
Posted: Sat Oct 11, 2008 10:27 pm
by FasterThanUr
For the 03 - 05 theres a lot of welding that needs to be done.Im not sure about the 99 - 02,but I think it could be done without a welder.
Posted: Sat Oct 11, 2008 10:52 pm
What has to be welded? some tabs? I thought it was just shortening the subframe
Posted: Sat Oct 11, 2008 10:58 pm
by 95FZR600
blackeyesandbruises wrote:What has to be welded? some tabs? I thought it was just shortening the subframe
The 99-02 you just need a cutting wheel to cut all the old shit off. You will need the under tray or battery tray for the easy install. Do a search on google for "heath's Fzr". his site will show you how to do it. I think most of us followed his tutorial.
Posted: Sat Oct 11, 2008 11:01 pm
Hey I just wanna say you guys on this site are just absolutely great Ive posted topics being the new guy and have never once gotten any slack, Kudos to you guys thank you.
Posted: Sun Oct 12, 2008 12:43 am
by FasterThanUr
for the 03-05 you need to cut off about six inchs and reweld it back on top laping it self so theres a spot for the rear to bolt up to.I guess ideally you would want to get some new square tube and remake the back part of the sub.i just recycled what i had cut off and finnished it up with some angle iron that I already had.maybe tomorrow I'll pull the tail apart and start a new thread with a write up of how to do the 03-05 tail swap.
Posted: Sun Oct 12, 2008 1:18 pm
by nynoah
Unless you are welding it, I would NEVER put a passenger in the back.
