I actually posted this over on FZR Archives but wanted to find out what everyone's got going on in this neck of the woods also!
For those of us in the northern hemisphere (especially the higher latitudes). Just curious as to what everybody has on their winter TO DO lists.
Even though I'm in California it still gets cold enough to not want to ride sometimes. Especially in the morning when it can get down to the 30s or 40s by the time I leave for work. Here's what I'm hoping to accomplish over the next who knows how long (not necessarily in this order). Some of it's pretty mundane but just thought I'd share anyways.
1 Get my seat properly shaved down and recovered (27" inseam
2 Pull off rear wheel to thoroughly clean swingarm (minor surface rust on chain side)
***Bought '90 FZR400 swinagarm***
3 Adjust rear brake lever to slightly lower angle (I've looked at this and the way to adjust does not seem obvious to me so I'll have to play with it)
4 Voltage Regulator swap (it seems fine now but from what I've heard it makes a mess when it does decide to crap out)
***DONE***
5 Clean all surface rust off the frame (very minimal, mainly on some of the weld joints on the subframe)
***DONE - Had frame and other stuff powder-coated***
6 Possibly blast / refinish headers / collector pipe (still up in the air on this one)
***See #7 below***
7 Possibly buy new exhaust (see #6
***DONE***
8 Check & possibly re-jet carbs, replace emulsion tubes, ignition advance (will probably bring her to Peak Performance in Simi Valley for this since they are Factory Pro authorized)
***Bought new main jets (110s) & emulsion tubes. Need to install then tune***
* 6, 7, and 8 all tie together. I've already received lots of good advice on this. Just need to make up my mind!
9 Possible front brake / master cylinder swap (I'd like to be able to take advantage of an adjustable reach front brake lever for my small hands)
***DONE - R6 lever fits like a glove***
10 Thoroughly clean all brake calipers & replace pads
***DONE***
11 Replace brake lines with braided ones
***DONE***
12 Move brake light further into the tail section
***DONE***
13 Replace broken right side clip-on pin (the one in the triple clamp that keeps the clip-on at the correct angle when putting it back on)
***DONE***
14 ???
Here are a couple things I need to do within the next few days:
1 Clean & re-wax chain
***DONE***
2 Replace broken tank bracket bolt (the one on the front side of the tank - it's seized up so it'll take a little work)
***DONE***
3 Tighten lower radiator hose clamp (the one down by the side stand - I've already tightened it once so the hose may need to be replaced)
***DONE***
Anyway, this should keep me busy for awhile! For those of you who need to park her for the winter, get the riding in while you can.
RIDE SAFE ALL!!!
Brandon
