steering lock (got mine to work)
shredex
Post by shredex »
does anyones work?
After studying my steering lock problem, and noticing that the bolt is to low by 1/16"
all I had to do was adjust one of the spacer on the triple trees which raised the top section with the ignition. Now it works!!
Yay!! not ther is a whole 10% less chance of someone stealing my bike from the original 95%... :banana:
Re: steering lock
shredex wrote:does anyones work?
Id like to make mine work but I have no clue how.
is it something easy to fix?
S,
mine works, most times the bolt bit gets bent or the hole in the frame gets burred.
judicios use of a file usually sorts it our
shredex
Re: steering lock
Post by shredex »
yamaha_george wrote:
S,
my key also wont come out when I turn it to steering lock.
i think the whole system might have been removed from my bike, not sure. Ill have to take a look again
shredex
Re: steering lock
Post by shredex »
oh, i see, its off center.
the bolt is about 1/8 inch to low, so it doesnt go into the frame hole
i think ill have to grind down the ignition mount so its set higher and will meet with the hole
Fartblood
Level 4.5
Level 4.5
Re: steering lock
Post by Fartblood »
Mine works, although my key is so worn I can take it out with the engine still running :yikes:
FasterThanUr
100+ Posts
100+ Posts
Re: steering lock
Post by FasterThanUr »
Fartblood wrote:Mine works, although my key is so worn I can take it out with the engine still running :yikes:
Mine too.I find it convenient,I can pull the key out and check my gas while ridingImage
90 FZR400/98 Fzr600 engine
Tom Tom GPS
05 R1 passanger pegs
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
I hooked my brake light switch to my throttle,so when I hit the gas everyone would slowdown and I would be gone :headbang:
shredex
Re: steering lock
Post by shredex »
my tank takes a seperate key so I can too :headbang:
ian
Level 2.5
Level 2.5
Re: steering lock
Post by ian »
+1! My buddy's '68 El Camino does that with the ingition. I thought it'd be nice cause then you'd never accidentally leave your key in the ingnition.
- William Burroughs
- Karl Marx
95FZR600
Re: steering lock
Post by 95FZR600 »
Mine dont work either.
ShogunTX
Level 4.5
Level 4.5
Re: steering lock
Post by ShogunTX »
Mine works oddly enough if I turn it far enough my hazards come on!
ian
Level 2.5
Level 2.5
Re: steering lock
Post by ian »
mine works! :headbang:
- William Burroughs
- Karl Marx
tommyj27
Level 9.5
Level 9.5
Re: steering lock
Post by tommyj27 »
yup, we've got a pickup that does that, very convenient!
docrider
100+ Posts
100+ Posts
Re: steering lock
Post by docrider »
mine worked the last time i used it but i rarely ever use it so ......
airtech R1 solo tail, russell racer front brake lines, dynojet stage 3 jets, K & N pod filters, V & H SS2R exhaust system, 89 gsxr 750 rear wheel
megaloxana
Re: steering lock
Post by megaloxana »
I tried getting mine to work couple weeks ago but no luck.
docrider
100+ Posts
100+ Posts
Re: steering lock
Post by docrider »
inspired by this thread i checked mine again and sure enough it works just fine
