R6 Rear Shock revisited (Please)
I have been searching for a while on both forums and have no answer.....
If I wish to raise the rear ride height and put in the '06 R6 shock I just bought, can I get away with NOT putting in longer dog bones? What is the effect of raising the rear? I am a hobbiest and not a corner thrasher, although I do ride hard in the corners occasionally, thus the reason I am putting in the R6 shock.
If it is recommended that the dog bones be changed can I use the ones from "linksforu" (3 lower holes, one upper hole in stainless)?
1993 FZR 600 (picked up for $500.00, all said and done put another $700.00 into her)
1995 Virago 750
1983 Venture 1200 AKA "the big comfey couch"
Note: I had to buy a 10X14 Shed for my toy's, the Wife has now threatened to make me move into it!!!!!
FZR Mods:
Stage 7 Kit/ K&N Dual Pod's
V&H supersport full exhaust
R6 Tail
R6 Twin LED undertail
R6 Tank
R6 VR mod W/fan
R6 Rear Shock
Iridium Plugs
Custom R6 Seat Covers
LED Flush Mount Turn Signals Front
R6 Front Brakes, Calibers & M/C
Barnett Kevlar Clutch and spring kit
Traksport Stator and cover
EBC Kevlar Bake pads
More to come!!!!!!!
http://www.picturetrail.com/flicks/5751781/preview
1995 Virago 750
FZR Mods:
R6 Tail
R6 Tank
R6 VR mod W/fan
R6 Rear Shock
Iridium Plugs
More to come!!!!!!!
- shredex
Re: R6 Rear Shock revisited (Please)
theres a guy in this forum that used an r6 shock. he had to weld up his own mount and relocate his battery to the very back.
ill find it for you.
h/o
h/o
The 06 R6 shock is supposed to be painless, a couple of spacers and some grinding of the bottom mount hole. The post states that the dogbones were made longer, that is where the question is????
1995 Virago 750
FZR Mods:
R6 Tail
R6 Tank
R6 VR mod W/fan
R6 Rear Shock
Iridium Plugs
More to come!!!!!!!
1995 Virago 750
FZR Mods:
R6 Tail
R6 Tank
R6 VR mod W/fan
R6 Rear Shock
Iridium Plugs
More to come!!!!!!!
- shredex
here we are!
viewtopic.php?f=30&t=266
he did a swingarm swap with it too. so I dont know if the height of the shock will be affected with the fzr swingarm
- FasterThanUr
I also did the mod.I dident have to weld the mount or do anything with the battery.Since I just moved to a state with lack of curves im not bothering with the dog bones for now.I just dropped the front about a half inch to make up the differance
90 FZR400/98 Fzr600 engine
Tom Tom GPS
05 R1 passanger pegs
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
Tom Tom GPS
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
I thought that making the bones longer would raise the rear?
1995 Virago 750
FZR Mods:
R6 Tail
R6 Tank
R6 VR mod W/fan
R6 Rear Shock
Iridium Plugs
More to come!!!!!!!
1995 Virago 750
FZR Mods:
R6 Tail
R6 Tank
R6 VR mod W/fan
R6 Rear Shock
Iridium Plugs
More to come!!!!!!!
NO longer bones lower rear end , short bones and your tail is stickin in the air ..like it dont care ..cpudoc6 wrote:I thought that making the bones longer would raise the rear?
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
Shorter bones raise it and longer bones lower it. Since there is a fulcrum it's the opposite of what is typical. Plus, most people ended up raising the rear after the shock swap to put it back to stock height. It's a bit lower and a softer spring so it needs to be raised or the res will hit the swingarm on simple bumps.cpudoc6 wrote:I thought that making the bones longer would raise the rear?
So than this will not work http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0275244754 to raise the rear after the shock install?
Is there an easy solution? I do not have a way to make my own, and lowering the rear is not gonna be a good thing.
1995 Virago 750
FZR Mods:
R6 Tail
R6 Tank
R6 VR mod W/fan
R6 Rear Shock
Iridium Plugs
More to come!!!!!!!
1995 Virago 750
FZR Mods:
R6 Tail
R6 Tank
R6 VR mod W/fan
R6 Rear Shock
Iridium Plugs
More to come!!!!!!!
Nope, those wouldn't help you at all. Haunter had some bones to raise the rear. He might still have a set. Otherwise I can make you a set but you'll have to give me some time. Super swamped at the moment.
i get a feeling you're around 200 pounds no ? i get a feeling spending money on an R6 shock is going to be a big disappointment for you perhaps.
Unfortunately a good new Penske 8100 series shock w/ reservior and lots of adjustability is close to $800, but the key is they set it / spring it / valve it for your weight and specifically for your FZR. I'm pretty sure that's what i'll be doing hopefully before next summer. That way you don't have to bother with dogbones at all.
I see you have a good list of modifications, just thinking of keeping with a high quality list to match such a good looking (assumed good-running) bike.
(likely if you get the R6 to fit you'll have to get a new 750(?) pound spring installed, or something along those lines) (i believe stock spring rate is 726 pounds)
What i'm also wondering is... did you ever put any Race Tech .90kg/mm or 1.0kg/mm springs in your fork? This will do wonders for the bike. It was probably the single greatest improvement i've done on mine. People always want to just "change the fork oil" but really this doesn't do very much.
Just food for thought.
You sir must be a physic! Yes 200 lbs. The shock that is on their now is the stock (origional 30k miles) shock and it is beat to death!!!!! Again as stated I am not looking for "race Quality" so the R6 is just a budget minded replacement. I like that fact that I can "Tinker" with the adjustments. I figure that if I keep the bike for more than a year, I will do the rear swinger swap, and all this will be a mute point. As far as the list of mods, they were mostly done prior to my ownership or found on EBay cheaply.
The front feels great, I assume it has something "non stock" in in. I dont know this for sure.
So bottom line, I got the shock for 35 bucks shipped and am hoping to get a set of bones that will bolt right up with out breaking the bank.........
Anybody have a set, or can make me a set of solid ones? (I saw the adjustable one that someone made, and while they are a great idea, I prefer solid)
Thanks
Thanks
1995 Virago 750
FZR Mods:
R6 Tail
R6 Tank
R6 VR mod W/fan
R6 Rear Shock
Iridium Plugs
More to come!!!!!!!
1995 Virago 750
FZR Mods:
R6 Tail
R6 Tank
R6 VR mod W/fan
R6 Rear Shock
Iridium Plugs
More to come!!!!!!!
if the front end doesnt feel like rubbish then something in it is non stock!cpudoc6 wrote:You sir must be a physic! Yes 200 lbs. The shock that is on their now is the stock (origional 30k miles) shock and it is beat to death!!!!! Again as stated I am not looking for "race Quality" so the R6 is just a budget minded replacement. I like that fact that I can "Tinker" with the adjustments. I figure that if I keep the bike for more than a year, I will do the rear swinger swap, and all this will be a mute point. As far as the list of mods, they were mostly done prior to my ownership or found on EBay cheaply.
Thanks
I have 15w fluid and extra preload and it still spaghetti
SOLD
SOLD
I used the 02 r6 shock and I had to remount the upper bracket and then it ended up raising the rear of the bike up 3-4 inches. I then had to use some lowering links to bring the height back down 3 inches. I dont think the r6 will work in the OEM upper bracket. Im almost positive it wont work. You will have to fab up an upper bracket. I can make you one for $35 shipped.
