everything seems to be working right too.
ill have to wait till after school to work on it
yeah one thing is for sure... If you own an fzr, you better own a battery chargerDr Rockso wrote:mine wouldn't start the other day because for the past few weeks i've been too busy to ride it . i ended up pulling the battery out to find that one of the cells was kinda low , so i put some destilled water in there , charged it up , and all is well now . these bikes are picky about power . when i would hit the starter it sounded fine for a while but it had just enough for the starter to sound ok , but not enough to start the bike . now that it's re-charged it fires right up . you might want to check that out .
i checked and all the levels are normalYAM93 wrote:Shred- Be sure to take the battery out and check the water level in the cells anyway, if you left the battery charging all day you could have boiled some of the water off. Battery power will slope off quickly over the next couple weeks if that is the case. Happens a lot with new batteries also.
(some battery chargers automatically turn off once full charge is reached, so this may not affect you, but just to be on the safe side)
Thats perfectly normal, the gas is supposed to have a blue tint to it. If it's yellow/tan then it's old gas.shredex wrote:The gas in my tank has a blue tint to it
