Clutch adjustment issue
95FZR600
Post by 95FZR600 »
Just wanted to give everyone a heads up about the lower clutch adjustment. I was having problems adjusting the clutch.
When I was doing the r6 swingarm swap I had to remove the front sprocket cover to get to the front sprocket. After removal I flipped it over to look at the internals and I could not believe the build up of gunk and road debri from the last 15000 miles. After removing all the goop in the parts washer and reinstalled the cover I made one adjustment on top and one on the bottom it was like having a new cable and lever position and feel is perfect.
For those of you having adjustment issues I suggest cleaning the inside of the front sprocket cover. And then lube the cable.
Hope this helps out.
shredex
Re: Clutch adjustment issue
Post by shredex »
I have that same r6 swing arm.
it seems to wide to fit the fzr 600 even with grinding down.
did you add more pics to your write up?
95FZR600
Post by 95FZR600 »
shredex wrote:I have that same r6 swing arm.
Sure did. Check it out! Im done and rode it today. Its awesome!
