keep popping turn signal fuse
I can not figure out why it pops the signal fuse. It seems to do it when i turn the handle bars left. Iv looked over the wires and they are all coated and taped. Iv popped a dozen fuses trying to figure this out and suggestions.
Re: keep popping turn signal fuse
ok there are 3 plugs up front a blue, black, and white all 3 are like 6 prong plugs iv elemenated it down that it will only pop a fuse if the blue one is plugged in and when i plug that one in the head lights come on, turn the handle bars back and forth and pop on the left. So now what?
- shredex
mine did the same damn thing.
when I put a turn signal on the front left and I turned it on, the signal stayed really bright, and when I turned the signal on, it blew the fuse.
Im just not going to put signals on mine
i dont have front signals on could that be the problem?? Il go try and put the signals on and see.
mine did the same thing , but in my case was my rear signal light, the wire was exposed and touching frame shorting out fuse .. So in my experience i would say there is a bare wire somwhere grounding out .. i would say check your harness up in the front and turn ur handlebars and see what wire moving ..just a thought
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
ok another 10 fuses blown this is some bs. There are no wires in the front that are hitting any metal iv checked them all. Now iv turn the handle bars straight and moved every wire as much as possible to try and get it to blow and nothing but the second i turn the bars all the way left it pops. Iv moved all wires while the bars are left to see if it will quit and nothing im completly lost and getting a bit mad. And yes iv taking the tank cover off and looked at the wires going through the frame and they are all coverd.
