stands
ian
Level 2.5
Level 2.5
stands
Post by ian »
Will any rear or front stand work with the 600? Now that I'm moved out of the house I need something for maintenance. At home my dad and I just used a motorcycle jack and two floor stands (for cars). I no longer have those tools.
- William Burroughs
- Karl Marx
ragedigital
4000+ Posts
4000+ Posts
Re: stands
Post by ragedigital »
I would contact PitBull. They should be able to tell you. You may have to go with a "vintage" stand which is slightly more narrow.
95FZR600
Re: stands
Post by 95FZR600 »
Universal stands will work for the FZR.
mossy1200
Level 5.0
Level 5.0
Re: stands
Post by mossy1200 »
The universal stands work but the fork bottom inserts need to be ground down on the thread side of the axel because the insert stub fowls the axel be put in and makes it hard to get the thread started when reinstalling it.
bucket
100+ Posts
100+ Posts
Re: stands
Post by bucket »
pit bull stand in their rear :thumbsup:
and I use 2 jack stands and a rigid pipe up front, and sizer jakes to get it up. Nerd
shredex
Re: stands
Post by shredex »
i guess the fzr is to heavy for double sided kick stands..
M in KC
Re: stands
Post by M in KC »
The standard Pitbulls will work on the Fizzs. You will need the rear stand with the pad adapters if you haven't installed spools. IMO I would go with the front stem stand rather than the fork stand. Then you can service you whole front end without having to come up with another way to support it for work on your forks, front tire repalcements etc. Again you will need the correct sized pin for the Fizz.
reelrazor
Wrench
Wrench
Re: stands
Post by reelrazor »
