What oil are you running?
What Brand/Weight oil is everyone running? I need to change mine, I believe that is causing some slippage of my clutch plus I need to fix my pan leak. Anyways, just trying to see whats better for the Fizz.
D&D Full Exhaust
YZF tank swap, 99-00 R6 Tail swap
R6 Front Calipers, SS Brake Lines, YZF Master Cylinder Swap
YZF/R6 VR
04 GSX-R 600 Mirrors
Integrated Tail Light, Flanders Front Flushmounts
Re: What oil are you running?
What's happenin'?
I barely changed my oil with Valvoline 10w40 4 stroke Motorcycle oil.. It's pretty cheap (found at Checkers or Autozone) , and you can't go wrong with Valvoline. Here's some specs on it:
http://www.valvoline.com/pages/products ... product=76
I also changed my oil filter with a K&N .. It has a "nut" welded on it so you can use a ratchet with an extension right thru the exhaust pipes.
My bike sees revs close to redline pretty often so I trust Valvoline..
Good luck
Good luck
1995 ,FZR 600,Factory Pro 1.1Ti Jet Kit, Yoshi slipon,K&N filter,elevation 4200 ft above sea level.
Carb settings: Main Jet 110, Starter Jet 52.5,Needle @ 3rd position,23m Floats,about 3 turns IM Screws.
80's-90's,Rap..music.?? http://www.last.fm/listen/user/unsmenar/personal
Always used Yamahalube 10w-30 or 10w-40 in the FZR. The CBR gets AMSoil 10w-40 MC.
- ShogunTX
- Level 4.5
Anyone using Lucas Oil additive?
I use Rotella non syn in the 600 currently (yay 15 buck oil change with filter)
used Rotella Syn before, thought it was making my clutch slip but my MC was the culprint
used Mobil 1 Racing 4T as well. cost the same as amsoil.
SOLD
SOLD
- FasterThanUr
I use Valvoline VR-1 50 wt with a K&N filter
90 FZR400/98 Fzr600 engine
Tom Tom GPS
05 R1 passanger pegs
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
Tom Tom GPS
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
Spectro Golden 4 10W-40 semi-synthetic (a bit expensive though)
never any problems here
also noticed this oil seem to help transmission shift more smoothly also
Where can you find this locally? Napa perhaps?YAM93 wrote:Spectro Golden 4 10W-40 semi-synthetic (a bit expensive though)
D&D Full Exhaust
YZF/R6 VR
Any really good motorcycle shop or dealer. if not they should be able to order it from a local distributor.
you won't find it at any place that sells car oil. i think it's around 11 - 12 bucks a quart... could be more now, not sure.
you can also get the standard type... it's a lot cheaper but still is better for transmission. i just went nuts and got the semi-synthetic expensive stuff just to try it out. the regular kind is VERY good and probably 7 or 8 bucks a quart instead.
if you can't find it try some Amsoil.... they are really great also. I use MAXIMA oil in my motocross bike, that's some good stuff too. Maxima Premium is about $20 a gallon from Dennis Kirk.
another oil thread????!!!!!!!
Leftover 07 Silver Ninja ZX6-R
**SOLD**
1990 FZR 600 Satin Black / Metallic Black Frame / Metallic Copper wheels
- Mods -V&H PIPE & HEADERS - 1999 R6 TAIL - 2001 UNDERTAIL - INTEGRATED LED TAIL LIGHTS - 2000 YZF TANK - 1995 YZF FRONT SUSPENSION AND GUAGES - MICHELIN PILOT POWER 120/60 ZR 17 - 1995 YZF REAR SWING ARM AND WHEEL W/HUGGER - METZLER ROADTEC Z6 170/60 ZR 17 - Xentec 8000K HID HEADLIGHTS - WHITE LED LIGHTING KIT
**SOLD**
Have there been a lot? I don't recall too many.NHFZR600 wrote:another oil thread????!!!!!!!![]()
Haha, I started one not so long ago..
I run Royal Purple 20w50 in my fzr but in the intruder I use castrol MC oil 10w30.
oil threads were a big topic that came up atleast once a month on the archives.
**SOLD**
**SOLD**
Yea yea yea... I tried searching for oil threads but the search engine on this forum isn't exactly friendly. Anything too small and it has a seizure, and anything that is said to often makes it want to punch a baby. So instead, I was lazy and started yet another... oil thread ...
D&D Full Exhaust
YZF/R6 VR
