grip change
mxryder21
Level 1.5
Level 1.5
grip change
Post by mxryder21 »
i wanna put some new grips on cuz their getting kinda hard but mostly im tired of those damn circles! So what size do i need? any grips i should stay away from? what do you guys use? whats the easiest way to change em out too? any tricks? :shocker
YAM93
Re: grip change
Post by YAM93 »
Galindo superbike grips from Dennis Kirk.
Use rubbing alcohol to get them on if you need to. Get some Scotts grip glue to hold them in place if necessary. I didn't even need glue for mine... once the alcohol evaporated they just stuck in place.
If they won't go on easy you can also shoot compressed air between the bar / throttle slide and the grip while pushing / twisting, it should help get it on there.
mxryder21
Level 1.5
Level 1.5
Re: grip change
Post by mxryder21 »
Im on denniskirk.com right now about to order some grips but they have two sizes listed. 120mm and 130mm. 120mm is not dual length. 130mm is dual length. both are for 7/8 bars. which ones do i get?
shredex
Re: grip change
Post by shredex »
mxryder21 wrote:Im on denniskirk.com right now about to order some grips but they have two sizes listed. 120mm and 130mm. 120mm is not dual length. 130mm is dual length. both are for 7/8 bars. which ones do i get?
I believe the 120 is for the clutch side, and the 130 is for the throttle because the throttle requires a wider grip, do to the thottle piece which makes the bar wider
mxryder21
Level 1.5
Level 1.5
Re: grip change
Post by mxryder21 »
they come in pairs though. its either a pair of 120mm or a pair of 130mm. im just gonna hold off till i hear back from yam93.
YAM93
Re: grip change
Post by YAM93 »
giggity giggity get the 130mm package.
:thumbsup:
mxryder21
Level 1.5
Level 1.5
Re: grip change
Post by mxryder21 »
you rock matt :headbang:
