I have my own project?
slayermd
Level 5.0
Level 5.0
Post by slayermd »
Wow. I usually come on here excited to see other peoples projects, but now I have my own!
Basically its a FZR 400 frame swap. There are a few reasons why I did this.
1. Because I had nothing else to do.
2. Its cool
3. Weight
Ok, so now for picture time!
Step one......
Old frame...Looking lonely.
Got the engine on a milk create.
Forks!!!
Painted the top triple while I had it off.
I have a face!
This is the reason I wanted to swap singers.
And...
This is what its at now.
I cant wait until this is done!
FasterThanUr
100+ Posts
100+ Posts
Re: I have my own project?
Post by FasterThanUr »
Nice :grinnod:
90 FZR400/98 Fzr600 engine
Tom Tom GPS
05 R1 passanger pegs
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
I hooked my brake light switch to my throttle,so when I hit the gas everyone would slowdown and I would be gone :headbang:
Fartblood
Level 4.5
Level 4.5
Post by Fartblood »
I like it already ;)
Genesis
Level 8.0
Level 8.0
Post by Genesis »
looking good
My FZR6 Rebuild
Post by thatkid »
Man it makes me want to start my 400 swap. I have too many other projects to finish first. Looking good though.
YAM93
Post by YAM93 »
nice man... is that an Ohlins rear shock ???
:thumbsup:
slayermd
Level 5.0
Level 5.0
Post by slayermd »
YAM93 wrote:nice man... is that an Ohlins rear shock ???
:thumbsup:
Yes it is. I saw your thread, your build is looking good too.
zero9243
Level 8.5
Level 8.5
Post by zero9243 »
:thumbsup:
i would have posted earlier but i had to get a new keyboard because the old one had jizz on it from that retarted shock.
Upgrades:
ragedigital
4000+ Posts
4000+ Posts
Post by ragedigital »
I CAN'T WATCH!
I love the flat black frame. What a great idea! :whistle
That bearing race was sent out today. My bad.... yes, I'm holding him up a little. I did send some extra parts though.
Can't wait! I know it's going to be bad ass!
Hey! Since you have both down tubes, from a 400 and 600. Can you see if they are different and report?
darrin
95FZR600
Post by 95FZR600 »
Nice man! Looking good. While your at it, do the yzf swinger and get a fatty on it.
haunter
Post by haunter »
ragedigital wrote: Hey! Since you have both down tubes, from a 400 and 600. Can you see if they are different and report?
yez pleez do!
Genesis
Level 8.0
Level 8.0
Post by Genesis »
I think I Might go flat black on my frame after seeing yours. Very nice
My FZR6 Rebuild
slayermd
Level 5.0
Level 5.0
Post by slayermd »
I haven't gotten much done in the past few days due to school and work. The only things Ive done was clean up the garage a bit, paint the front wheel and mount the rear plastic fender thingy. So here are some pics!
Front wheel before.
]Image
And after. I know, its a shitty paint job.
Plastic fender mounted. I didnt know where it mounted up to, so I just drilled and tapped a new hole for it!
BTW, the down tube weigh in at about the same. The only difference that I saw was different mounting tabs for the fairings.
slayermd
Level 5.0
Level 5.0
Post by slayermd »
So, I got the part I needed from Rage super duper fast and that allowed me to get the frontend back on. Anyway, pics!
With the YZF tank. Sexy.....
w00t!
I got this idea from manveru and his build.
With the forks back on.
All that I have left is get the tank mounted, some electrical, chain and body work on. I love being a monkey wrench! :banjoman
Post by thatkid »
She is looking nice. Who cares about a crappy paint job. At 90mph the camera won't be able to tell. And hopefully they'll be looking at the downed knee vs the front rim.
Bones are out getting powdercoated. I will ship them out when I get them back.
