How big can I go?
Posted: Fri Sep 05, 2008 10:23 am
by 1BadFZR600
My 94. 600 Rear tire is flat in the middle..HUMM
I wonder what caused that?
..HA Anyway what is the biggest tire I can go with? Or is it better it do the Swingarm swap?
Re: How big can I go?
Posted: Fri Sep 05, 2008 10:25 am
by ragedigital
The biggest you can go is a 150. A 160 will rub unless it's on a 17" rim.
Posted: Fri Sep 05, 2008 10:26 am
by 1BadFZR600
Thanks Darrin!!
Posted: Fri Sep 05, 2008 10:33 am
by 1BadFZR600
150-70-18?
Posted: Fri Sep 05, 2008 10:47 am
by ragedigital
150/60ZR18
BT-014. I thought they made the BT-016 in an 18", but I guess not.
Posted: Fri Sep 05, 2008 10:48 am
by 1BadFZR600
My tire now is a 140/70-18 ...
Posted: Fri Sep 05, 2008 11:06 am
by ragedigital
It is a slightly different profile, but I'm sure you will like the 150/60.
Posted: Fri Sep 05, 2008 11:57 am
by 1BadFZR600
Anyone got one for sale? If not where do yall get tires from?
Posted: Fri Sep 05, 2008 12:45 pm
by tommyj27
1BadFZR600 wrote:Anyone got one for sale? If not where do yall get tires from?
anywhere that has them in stock! i would check dennis kirk first because they have the lowest price i've found.
Posted: Fri Sep 05, 2008 12:48 pm
by 1BadFZR600
OK.....Im checking now.....
Posted: Fri Sep 05, 2008 4:29 pm
by 95FZR600
You saw my bike and Im running a 150 on it. You can go 160 but you will have to space out the brake arm.
Posted: Sat Sep 06, 2008 5:19 am
by match417
ragedigital wrote:The biggest you can go is a 150. A 160 will rub unless it's on a 17" rim.
hmm...i always assumed that I could go with a 160 on a 17 inch rim but i never knew for sure, what about a 170 on a 17?..and is there a 17 incher that i could just put on and ride? or at least one that I only have to change the rotor or add spacers? Will a yzf600 rear tire swap in directly? I know it's a 160/17, and i think the rotors are the same, or at least the same size. I'll probably check my friends bike in the morning.
All i want is a 180 on a 17 and i'll be happy, if i have to pull off my swingarm and weld it somehow, i will..i've even thought about a fat boy rear tire if i'm gonna pull it off to weld, but i'd have to modify the front sprocket..sigh
Posted: Sat Sep 06, 2008 8:37 am
by ragedigital
You can't go any larger than a 160 with a 17" rim. Even with that the brake arm has to be slightly flattened.
To get anything larger, you'd have to go with a YZF600 swingarm conversion. Then I do believe you can fit a 180, but you won't be able to use the rear fender.
A YZF600 rear rim is too larger for the stock swinger.
Posted: Sat Sep 06, 2008 11:06 am
by PIMPMYFZR
I don't know about you guys and not going more bigger then 150. I've been running mine 160-60 the whole time I've had my bike! The sportmax dunlop had no clearance issue what so ever the continental on other hand rubbed on the brake arm so it differs on what brand tire you get and you can swap out that torque arm for a different one
