Tail light upgrade
Tail light upgrade
Well i got tired of that ugly tail light so for now this is what im going to run $25 upgrade
Re: Tail light upgrade
Thats different and looks bright enough to back it into the garage.
i was only a foot away when takin the pic.......now when i get money il do the r6 that look is way to cool but for now this imo looks better than stock
erawtik wrote:i was only a foot away when takin the pic.......now when i get money il do the r6 that look is way to cool but for now this imo looks better than stock
Explain a little. What kind? Where did you buy?
Well I bought the light at autozone and I think the brand was Blazer.
Nice looking BUT is it legal in all states In the UK lights have to be E marked as being legal according to EU law (PITA)erawtik wrote:Well i got tired of that ugly tail light so for now this is what im going to run $25 upgrade
that is a replacemnt LED brake light for a cargo trailer .. but as you see now its also a fzr replacement tailight .. nice job i always wondered if that thing works on our bikes ..ive seen them and thought about it but it wont fit into my airtech tail without hacking the fiberglass to make it fit
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
- Luke-a-Tron
I want to do two round brake lights to go with the headlights. I hate fiber glass splinters too much though.
Ya i liked the round ones they have but they where pretty big and that would mean some fiberglass modding. Dont know if it worth the time and effort to do it or just do the R6 tail. The good thing if you where to do the 2 rounds you can use them for blinker as well. mabey i should this winter
My tail light also wired as integrated blinkers
i did this once, unfortunately i couldnt get the angle of the leds right to shine bright enough to see real well in the daylight. went with an ebay undertail. but it was fun to figure out at least! i like your taillight, looks newer, and bright, a great upgrade.
I did that.
- Dborne1
Looks great! Any ideas of how many amps it draws? May have a charging issue if too much? Usually LEDs draw less so it might be ok.
1992 Yamaha FZR600 california model. Bridgestone bt014's, 520 kit (14-47), rear spoils, Vance&Hines slip on, 1997 header w/o Exup, Gsxr600 steering stabilizer(custom set-up), R6 mirrors, (custom made) chain guard.Stock air box w/ K&N filter. Vortex bar end sliders.
Slotted pick up coil approx. 3 degrees.
Scorpion exo-700 helmet(San Diego House of Motorcycles)
Frank Thomas jacket (cycle Gear)customed zippers to fit-
my alpine stars pants(craigslist)
Held gloves ( bought in Greece) &
Alpine stars smx boots(craigslist)
looks a little off center? maybe its just me
Upgrades:
- Luke-a-Tron
Ghetto fabulous! I'm surprised it looks as good as it does. Integrated signals are a bad idea though. From any more than 5 feet away it gets really hard to tell which way you're turning. A lot of the time it's hard to even tell it's doing anything or if your just braking. A bad idea IMO.bobee wrote:My tail light also wired as integrated blinkers
If you put red LEDs in a red housing, you won't get much light out unless the lens is the exact right color of red. The red lens filters out light that is not of a particular wavelength. Since LEDs emit light only in a narrow band of wavelength, unless the lens is just the right color, most of the light will be filtered out. White LEDs emit a much broader spectrum of light and are way more likely to emit a wavelength that gets through the filter.
Ive left some led's on allnight <forgot them on> and my bike started right up , now my HIDS are hardwired with a toggle if i forget those on .. then imDborne1 wrote:Looks great! Any ideas of how many amps it draws? May have a charging issue if too much? Usually LEDs draw less so it might be ok.
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
