Temp guage shows different readings & cooling improvements
Posted: Wed Oct 19, 2016 11:57 pm
When running, it's about half a gauges worth off. For example, it will be around the middle mark while running/idling but if I kill the engine with the key ON, its up near the red.
Is this normal or is my gauge done? Since it still works, which is the more accurate temp so I can keep an eye on it?
Its in a FZR400 frame and the radiator looks too tiny to be effective. There's also no oil cooler on it
I did some sleuthing online and found a few larger ones that might fit but would putting just a push fan be sufficient? I have the stock pull fan but the valve cover is right up against the radiator, don't suppose I could reverse the polarity to make it a push to put in front?
Pros and cons to each method?
