Any one know how to bypass high/low beam switch?
Posted: Mon Aug 22, 2016 10:34 pm
So exactly what the title says. Lost headlights in the front, checked the bulb with a new one, and still not working. Gauges still illuminate (So it's not the starter). If I toggle the high low beam fast enough the lights start working, and or hold down the high beam switch down really hard.
I have already tried to unscrew the two Philips head screws from the bottom of the entire switch assembly, but they were already stripped. And apparently the previous owner used some sort of plastic epoxy to seal the two ends of the assembly, no amount of prying works, unless I'm willing to destroy the damned thing (Which I'm not).
Any ideas on how to install a separate switch bypass just for the headlights?
-Thanks!
-Thanks!
